Fine tuning quadrajet E4ME
Old Jun 23, 2014 | 08:04 PM
rlsterling3's Avatar
rlsterling3
Default Fine tuning quadrajet E4ME
Ok, so I've rebuilt the carb, new dizzy, new plugs, new wires, hooker super comp headers flowing through 2 1/2" exhaust to dual Flowmaster delta 40's. I've got the basic adjustments done in the carb. It starts right up, idles fine right around 700rpm.it seems to be fairly quick but I feel like I'm still lacking some "oomph" when I go WOT. Can someone please explain the process of fine tuning to get the most performance from the carb. I've rebuilt power the instructions in cliffs book. I'm looking for information on the following :
1. Fine tuning the air / fuel mixture screws
2. Adjusting the APT screw and lean and rich stop screws
3. Adjusting secondary pull off rate
4. Am I missing anything else here?
On the secondaries I'm not sure if I have to make an adjustment to the vacuum dashpot. How can I time how long it takes to release?
The car is an 81 c3. motor has been bored.. 30 over, healthy cam, flat top Pistons. The car sounds great and runs fine, no check engine light. To my knowledge everything is running good, I just feel like it should have a bit more power in there, my gut says it's the carb as I haven't made any "fine tuning" adjustments. I'd love to get this running right. Any help out there? Thanks as always!
Old Jun 23, 2014 | 08:22 PM
jnb5101's Avatar
jnb5101
email lars at v8fastcars@msn.com for his excellent paper "Tuning Qjets".
Old Jun 23, 2014 | 08:28 PM
Shark Racer's Avatar
Shark Racer
SR: With an E4ME, you set the idle mixture screws until you're in the center of the dwell gauge on a 6 cylinder readout. This allows for calibration in either direction.
SR: There is no APT screw on an E4ME, just the lean and rich stops. There's a range you want them to travel in, and a baseline for rich stop. You should check around on thirdgen.org, tons of info on tuning E4MEs there.
SR: This is done by enlarging the restriction. Alternately, you can get ones pre-modified from Cliff Ruggles. I'm either completely inept or it's a difficult process. These pulloffs require you to straighten the vacuum barb and then slowly drill out the restriction. I usually end up mangling the diaphragm by overheating. Oops. So have Cliff do it.
SR: Retract the pulloff link completely with your finger, cover the vacuum source with your finger. Hit "START" on your stop watch and pull your finger off. Hit "STOP" on your stop watch when the link stops moving out.
Responses inline, in bold.
Hope that helps.
Old Jun 23, 2014 | 09:11 PM
Fast81's Avatar
Fast81
I just received Lars papers a few weeks ago and he states they dont pretain to the 81 E4 carb or the 82 TBIs
Old Jun 24, 2014 | 03:03 AM
Shark Racer
Very little of Lars' paper is for E4MEs. The secondary circuit on an E4M may be dealt with the same as the secondary on an M4M. Primary side and idle mixture runs off the ECM and requires a different strategy.
Old Jun 24, 2014 | 05:29 PM
rlsterling3
Hope that helps.
Awesome response, thanks! I've been reading so much, search after search, etc etc that I completely forgot about setting the dwell! Last night I made a few adjustments to the secondary pull off spring, first two I had bog, the last one seems to have nailed it. I guess next I'll adjust the air fuel mixtures. So should I adjust the for max vacuum or for dwell? I've got both the dwell meter and vac tester so I could do either. I can't remember the name of it now but I know I measured the travel (?) through the top of the carb and I'm right at 2/32. If love to finally get this dialed in!
Old Jun 24, 2014 | 07:19 PM
Shark Racer
Adjust idle for middle of dwell travel. The carburetor and ECM will set it to stoichiometric no matter what you do. So if you turn the screws in, the speed at which the MCS cycles the idle air bleed will change to get the mixture back to stoich.
I think travel of the MCS (between rich and lean stop) is supposed to be more than 2/32, but can't remember. I'd have to do a crawl on thirdgen.org again to figure that one out.
To Fine tuning quadrajet E4ME
