Headers/Side Pipes Pros Cons?
Does it require rejetting the carb to richen up the mixture. Can they adversely effect the valves?
Thanks!
Diesel
Valves will not be effected by air going up the pipes if that is what your concern is. I have been running them for decades.
Otherwise you have the two main issues already in mind.
What changes would you recommend to the stock carb?
Thanks,
Diesel
Among the pros is the sound of the exhaust, who needs a radio? There definitely is a reduction in the cabin temperature with side pipes and they also open up the underside of the car for engine, tranny and diff work. No having to remove the exhaust to get at things. Also, what price can you put on the looks?
Pros: Good looks, great sound
Cons: Burned legs is obvious, but, there were more for me. Getting in and out of the car was a real pain in the rump! I am 6'2" and about 220 and these cars are a contortionists dream at the best of times. Practice having to rotate your left leg out another 6" everytime you get out of the car, same with your right and then try to stand with your feet that much further from the sill. Its a form of Tai Chi for sure!
Sound is nice, but, somewhat embarrassing in the evenings when you get stopped in traffic and your cool sounding pipes are blasting into the open window of the police car next to you!
Mine also wore holes through my rocker trim where the side pipe clamp touched. Some people choose not to reinstall the trim because it may require you to trim them to fit. The trim is getting hard to replace, so, should be considered.
If you have a chrome bumper car, you are left with the holes and bezels in the rear from the stock exhaust. This was a major issue for me in my decision.
Lastly, they have been proven not to perform as well as a modern high flow X pipe system with good mufflers.
In summary; Pros: looks and sound, Cons: lots.
Your mileage may vary!
If utility, superior handling, comfort and low decibel levels were important to me, I wouldn't own a Harley much less a 38 year old Corvette!!! LMAO!
Thanks for the input guys!
NOW, if anyone has a used set of said headers and side pipes in very good condition they'd like to part with, please reach out to me at 443-250-3726 or cjgaller@gmail.com. I've got my PayPal at the ready!
Cheers!
Diesel
Heat shields are a MUST. Really nice ones from Bangcock Dean, lesser from Cobrastuff.com.
Chrome pipes become a cleaning issue. I have the black ones and am going to have them ceramic coated as close to chrome as possible; $400.
Damage to the rocker panels is correct, best to dimple the rockers where the tube clamp bolt is. Of course likely to damage paint if painted.
Sound is the best!
My friend had them on a T top car and all you heard was the one side howling in your ear whenever you're next to something. His pipes were chambered, maybe baffled would be better.
Thanks!
Diesel
Went for the SS and max flow mufflers
Expensive but well, well worth it.
No engine mods, just make sure you don't have angled plugs or the wont fit.
I installed shields on my because they really get hot
Can put my hands on shield when car is running, warm to the touch.
Vet sounds nasty and no back pressure.
They are loud but you will get use to it.
Not that hard to install either.
Diesel
