a/c
Old Jun 25, 2014 | 01:21 AM
1980 L-48's Avatar
1980 L-48
5th Gear
Default a/c
hi blake again.. the vetts a/c unit doesn't feel like its forcing a high volume of air when on high.. so would that be a bad blower, bad control panel...?
also can i run new a/c coolent in the old system once issue is resolved?
Old Jun 25, 2014 | 06:25 AM
mikep3's Avatar
mikep3
If the blower motor changes speed, I would think it's filled with debris or the vacuum actutors are not working or stuck.
My motor died and when replacing it I vacuumed out the heater box via the whole were the motor was installed.
Old Jun 25, 2014 | 08:46 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by 1980 L-48
...can i run new a/c coolent in the old system once issue is resolved?...
Any automotive AC shop can test and recharge your system. You cannot mix refrigerants (R12 and R134a).
Old Jun 25, 2014 | 01:49 PM
1980 L-48's Avatar
1980 L-48
5th Gear
even if the system has no refrigerant in it left?
Old Jun 26, 2014 | 02:03 AM
zoomee's Avatar
zoomee
7th Gear
My ductwork under the dash was was misaligned and leaking conditioned air. I removed glove box insert and duct taped joints and aligned ducting. I also replaced my motor and fan wheel while I had the drier out...This made a big difference too.
To a/c
