Anyone running Demon's ZZ4 carb??
Old Jul 23, 2002 | 10:39 PM
Sigforty's Avatar
Sigforty
Cruise-In IX Veteran
Default Anyone running Demon's ZZ4 carb??
I am having a hell of a time getting the Road demon to work right on my zz4. I called Demon today and they told me they make a specific carb for the motor. It is Demon #1282010Czz4. It is a mech sec. 650 speed demon. It is suppose to be already tuned for the motor. I was wondering if anyone is running this one yet? I am considering buying it and selling the road demon.
Mark B.
Old Jul 23, 2002 | 10:57 PM
Fevre's Avatar
Fevre
Default Re: Anyone running Demon's ZZ4 carb?? (Sigforty)
When you bought the carb did you buy it specifical for the zz4 and if so, did you tell whoever you bought it from what you where buying for? If so wonder why they did not know about the special carb? Just curious.
Old Jul 23, 2002 | 11:44 PM
A C's Avatar
A C
Cruise-In II Veteran
Default Re: Anyone running Demon's ZZ4 carb?? (Fevre)
I don't have a ZZ4, but I am running a Speed Demon 650 mechanical secondary carb on my 69 L46. I must say this is the best carb I have ever had on this motor. I have had a Rochester, Holley 4160, and a Holley 4150. None of them compare to this one. I just bolted it on out of the box, with no modifications. It fires on the first crank over, no pumping the gas. It idles great right at startup, even though there is no choke, and the driveability is great. :cheers:
AC
Old Jul 24, 2002 | 10:12 AM
Sigforty's Avatar
Sigforty
No I actually bought the carb for my old 270 horse motor. The quadrajet crapped out and I deciede to upgrade to a demon. From the horse power ratings and other info I determine the road demon was best. It ran great on the old motor, but is give problems with the zz4. I only found out about the special carb when I called to get help about getting the road demon to work on the zz4.
Mark B.
Old Jul 24, 2002 | 11:53 AM
Cookwithvette's Avatar
Cookwithvette
I had the same thing happen to me. Bought the Road Demon for the old engine, worked GREAT. Then I realized the motor was crap. (long story) Bought a ZZ4, havn't had the pleasure of starting it yet but from the sound of things I'm now looking at a carb that might not work. I found the "ZZ4 Carb" in the Scoggin-Dickey catalogue and from the sound of your posts looks like I'll be getting one soon.
$454 mechanical secondaries
$414 vacuum secondaries
Ouch either way. :eek:
What sort of troubles are you having with the Road Demon?
Old Jul 24, 2002 | 12:47 PM
theandies's Avatar
theandies
Default Re: Anyone running Demon's ZZ4 carb?? (Cookwithvette)
I am running a Lars rebuilt and tuned Q-jet. I runs great and I think the Q-jet is the carb GM used to Dyno the ZZ4 (don't quote me on that though).
John
Old Jul 24, 2002 | 02:44 PM
Sigforty's Avatar
Sigforty
Well I cannot get the Road demon to idle below 1100. I also cannot get it to stop running rich. Those are the two problems I am having. Before I advanced the timing it was idling around 800-900 rpm and still ran rich. I am guessing that the carb is not moving enough air at idle.
Mark B.
Old Jul 24, 2002 | 04:18 PM
Cookwithvette
Yep, carb's too small.
*sigh* Looks like I know where my next paycheck is going. :(
To Anyone running Demon's ZZ4 carb??
