Garage necessities for c3 resto?
I will be doing a body off on my 75 in a one-stall car garage :crazy: Unfortunately...the garage hasn't been cleaned in about 10 years and was stacked with useless things acquired over several years. Well...the junk is hauled out, it is nearly organized, and I even drywalled, and tiled the floor to make it a little more cozy since I'll be spending so much time in there:)
We have a plenty of hand tools. I just ordered a 60 gallon 5.5 hp 2 stage air compressor. I plan on picking up a parts washing station, sand blasting equipment, and I may build a blasting cabinet. What other things should I be purchasing that will be helpful in redoing the vette?
Cruise-In VI Veteran
Cruise-In VII Veteran
Re: Garage necessities for c3 resto? (Brett K)
Complete set of air tools, ratchets, impact, air chisle, etc. to name some obivous additions to your compressor.
Platinum Supporting Dealership
Re: Garage necessities for c3 resto? (Rocket Ron)
Grinding wheel, LOTS of overhead lighting, jack stands, good jack, work bench, nice fan, ext. cords, angle grinder, fire extinguisher, fire alarm, CO alarm
Beer cooler, phone for ordering parts and calling bank, tunes, lots of overhead lighting, rottweiler...did I mention beer cooler? :cheers:
Re: Garage necessities for c3 resto? (Stevo)
Check out my pics before you jump in feet first.
A 4-4.5" angle grinder !! I used to use an air powered cut-off tool, but
the electric angle grinder has MUCH more power. Great for destructive
removal of: body mount bolts, rear strut rods, door hinge bolts, windshield frame.
Also, get flap disks and wire brushs for cleaning up the metal.
I have a siphon sand blaster - but it makes one hell of a mess !! :reddevil
:seeya
[Modified by Daves_rusty_75, 1:05 AM 7/24/2002]
:seeya
One old but very good working refrigerator. (cold beverages)... and
one very deep bucket of patience. Good Luck :cheers:
Re: Garage necessities for c3 resto? (KENS78SILVERANNIV)
To finish the right garage you need an old radio conected to a battery and one of those wall calendar with a nude chick on it :D
:cheers: :cheers: :cheers:
Re: Garage necessities for c3 resto? (88'Cubka)
You need a digital camera and a lot of storage room. One car garage will be a pain because the lack of space to have work benches in to put stuff on as you work on it. Do you have a hoist and engine stand? You will need a couple of real good jacks, one won't do, and plenty of stands. Take pics from every angle and of what type of bolts are used where. A big pad to take notes on.
Neil in Tenn
Neil in Tenn
Re: Garage necessities for c3 resto? (Nomad78SA)
A MANUAL
A VISA CARD
A HICTH ON A TRUCK
A ROLL OF DUCT TAPE
A SMALL CLOSET IN THE CORNER TO LOCK YOURSELF IN TO SCREAM
A BIBLE TO PRAY WITH
P.S. Enter the phone number in your speed dial to a good mechanic
GOOD LUCK
A VISA CARD
A HICTH ON A TRUCK
A ROLL OF DUCT TAPE
GOOD LUCK
A 20 ton press if you're going to do the suspension or differential. A MIG welder would be nice too. I'm looking for one now myself.
Gary
Gary
1975 Assembly information manual (A.I.M.)
1975 Shop manual
Timing light
Vacuum gauge
Number for pizza place with late night delivery
1975 Shop manual
Timing light
Vacuum gauge
St. Jude Donor '08-'09
A blasting cabinet is a must.
Saw horses and plywood. (You can set them up as needed and then store them neatly since you don't have much room.)
Bailing wire (For hanging up parts to paint.)
and last but not least...
Jackstands, jackstands, jackstands, jackstands!
Working out of a one car garage myself. Luckily I have loads of storage in a crawl space under the house. Don't forget a patient wife :lol: - if you have one that is. Right now I have the body on a dolley in the driveway & the frame in the garage. With the Mustang on the other half of the driveway the wife has to park in the street. That won't last to long :)
Re: Garage necessities for c3 resto? (70BBvert)
1. Beer
2. Radio
3. Cordless phone with Lars' number in memory #1, mountainmotor's in memory #2
4. Punching bag
5. Beer
6. Fire extinguisher
2. Radio
4. Punching bag
5. Beer
I will definately not start a project like this again until I have the following.
1. A GOOD vise.*****
2. Press.*****
3. Parts Washer.***
4. If space and money permit. A blasting cabnet.***
:cheers:
2. Press.*****
3. Parts Washer.***
:cheers:
Re: Garage necessities for c3 resto? (Gordonm)
Put your air compressor on wheels so you can roll it out of the garage to run. The noise will drive you nuts.
