80 AC condensor housing
Old Jun 27, 2014 | 10:46 AM
Slotehog's Avatar
Slotehog
Default 80 AC evaporator housing
Alright fellas...here's the situation: the previous owner removed just about everything to do with the ac with exception to the condensor housing (not sure if that's what it is called). I thought I removed all of the nuts and bolts holding it to the firewall and all that was holding it was the black adhesive. However, during my attempt to get it free, I have cracked the fiberglass at the bottom of the housing. Before I do anymore damage, are there any hidden nuts/bolts that I am missing? Here are a few pics:
Old Jun 27, 2014 | 10:48 AM
Slotehog's Avatar
Slotehog
Here's photo 2
Old Jun 27, 2014 | 11:10 AM
qwank's Avatar
qwank
condenser is in the front. The evaporator lives in that box
Old Jun 27, 2014 | 11:17 AM
Slotehog's Avatar
Slotehog
You're right. That was my mistake. Any other suggestions for removing the evaporator housing?
Old Jun 27, 2014 | 11:56 AM
LannyL81's Avatar
LannyL81
Going from memory: There is a bolt at the bottom on the inside..... or was it the top??? Check inside and outside perimeter.....I remember there was one that was quite hidden.
Old Jun 27, 2014 | 04:52 PM
blackcorvette1980's Avatar
blackcorvette1980
Default Yes there is a bolt on the inside passenger footwell
Old Jun 28, 2014 | 12:07 PM
Slotehog's Avatar
Slotehog
That's correct. It appears from the engine bay side that there are two studs (the one up top with a nut) but the bottom "stud" is just the bolt coming through from the passenger side footwell. Once that was removed it came out no problem.
With it out, this is what I found hidden in the evaporator box
Old Jun 28, 2014 | 09:22 PM
CaseyJones's Avatar
CaseyJones
St. Jude Donor '15-'16
Mulch!
To 80 AC condensor housing
