69 Corvette - under carriage thumping noise
Old Jun 28, 2014 | 09:57 AM
afnoce's Avatar
afnoce
Default 69 Corvette - under carriage thumping noise
Hi Everyone,
I have a four-speed manual transmission C3 Vette that's been making a thumping noise.
The noise is not a one-time "clunk or thump" but when it happens, it's a bunch of them strung together (i.e. thump, thump, thump, thump). It's almost like the sound of something being stressed or creaking but loud. The sound is not uniform in duration...can be faster or slow.
It seems to only make this noise only when the car is in first gear (thumping starts when it get the car moving from a dead stop) or when I have the gear in reverse.
Once the car is in 2nd or any other gear, there's no thumping at all. I've done a search on the forum for a similar issue and just not sure if I have a problem with the differential or if this sounds like a problem with the transmission.
I greatly appreciate any suggestions, assistance or words of wisdom you can offer. Thanks in advance for your help.
Fred
Old Jun 28, 2014 | 07:28 PM
GRipp 73's Avatar
GRipp 73
Sure you don't have a rabbit stuck underneath that is kicking your floor pan?
Ok, I have no idea what it is at this point, but let me ask a question if I may. When you hear the sound, do you feel it anywhere? Butt of your seat? In the shifter? Gas pedal? Brake pedal? Steering wheel?
With it only being in first gear and maybe reverse, I would think something in the transmission,.
Wait, let me ask a second question. Does it do this when going in a straight line in first and reverse, or are you making a turn or a sharp turn?
Hope you find an answer.
Old Jun 28, 2014 | 08:00 PM
AboveTheLogic's Avatar
AboveTheLogic
Good questions. I had a similar sound that required a diff rebuild. The yokes were worn out to the point where they were falling into the rear end further than they should and they were hitting the diff housing.
A related symptom was a noticable negative camber on the rear wheels, even when the control arms were pulled all the way in.
Old Jun 28, 2014 | 09:19 PM
CaseyJones's Avatar
CaseyJones
St. Jude Donor '15-'16
Check the trans mount and front differential mount.
Old Jun 28, 2014 | 11:22 PM
afnoce's Avatar
afnoce
Thanks for the reply...if only it were a rabbit! The thumping noise seems to come from below at the rear end of the car. The noise is definately unrelated to turning...I'm in a straight line either in first gear or in reverse when it happens.
Old Jun 28, 2014 | 11:25 PM
afnoce's Avatar
afnoce
thanks for the reply...will check the differential. Have not noticed anything related to negative camber.
Old Jun 28, 2014 | 11:26 PM
afnoce's Avatar
afnoce
Thanks for the reply...will check both mounts as recommended.
Old Jun 28, 2014 | 11:50 PM
CanadaGrant's Avatar
CanadaGrant
The front rubber diff mount bushing is it. It has nothing to do with camber. A ten buck part and a pain to install.
Old Jun 29, 2014 | 09:09 AM
afnoce's Avatar
afnoce
Thank you for the reply. Will be getting under the car today to check that out.
Appreciate everyone's help on this...again thank you
Old Jun 29, 2014 | 09:50 AM
havesometo's Avatar
havesometo
Check your exhaust pipes.
Old Jun 29, 2014 | 11:10 AM
afnoce's Avatar
afnoce
Thank you for the reply. Just had new exhaust pipes and Magnaflow mufflers put in this week...noise was happening before the exhaust system was installed.
To 69 Corvette - under carriage thumping noise
