Low air volume from your AC?
Old Jun 29, 2014 | 09:29 PM
'75's Avatar
'75
Default Low air volume from your AC?
This is on the 77 I have for sale.
Well I wasn't happy with the air flow from the AC. I went and got a new blower and motor for a 86 vette and made up a 3/4" spacer. When I pulled out the old motor, I found part of the reason for low air flow. It had the wrong blower wheel on it. It was about 1/4" shorter than stock. The one on the left is what came out of it, the one on the right is what should have been there.
The one on the right in this pic is the new one with the homemade wood spacer.
Before I installed it, I stuck my hand in the hole and found it nearly full of leaves. I stuck the vacuum hose in there and sucked it out then stuck the camera in and took a pic. Still lots of leaves.
Put an air blower in the back side of the evaporator through the resister hole and blew through it then vacuumed it some more. Nice and clean now.
I put in the new blower with the spacer as well as a heavier ground wire. This thing moves air like it should now. Worth the time invested and the price of the new blower.
Old Jun 29, 2014 | 09:38 PM
qwank's Avatar
qwank
even got a tootsie roll wrapper in there.
How tough was it to get the motor out? I kinda want to see if mine is all full of leaves too
Old Jun 29, 2014 | 09:43 PM
'75's Avatar
'75
I had to remove the coolant recovery tank and then the five 1/4" hex head screws. Putting the new one in was a little harder, I put the motor and spacer into the inner fender area then put the blower wheel on it and then put the whole assembly in with longer screws.
Old Jun 29, 2014 | 09:59 PM
qwank's Avatar
qwank
that doesn't sound so bad. it looks really tight in that area
Old Jun 30, 2014 | 09:25 AM
junkman123's Avatar
junkman123
im pretty sure your old blower would probably work fine now that all the leaves are gone
Old Jun 30, 2014 | 10:31 AM
BLUDICE's Avatar
BLUDICE
How does the leaves - etc get in there, and what can be done to prevent it from happening in the future??
Old Jun 30, 2014 | 10:45 AM
junkman123's Avatar
junkman123
i think they get sucked in from the freash air vent in the cowl,the hole should have a screen over it but sometimes they break,mine sit for a while and the heat/AC box was full of nuts and squirrel nest
Old Jun 30, 2014 | 10:59 AM
chvet73's Avatar
chvet73
Even cleaned out the old blower will not come close to the output you get from the C4 blower. This upgrade is well worth doing.
Old Jun 30, 2014 | 12:17 PM
Solid LT1's Avatar
Solid LT1
On later C3 Vettes there are screens in the cowl area to prevent accumulation of debris in the HVAC system.....starting around 1973 model year as I recall. Putting some screen in the upper cowl area is never a bad move on a restoration.
Old Jun 30, 2014 | 06:31 PM
'75's Avatar
'75
No it wouldn't, it was the wrong blower and this isn't the first vette I've done this to. It's like night and day difference.
To Low air volume from your AC?
