Ignition problems...Resistors...
Old Jul 24, 2002 | 11:34 AM
Aaron-74's Avatar
Aaron-74
Default Ignition problems...Resistors...
When I had my Accel coil it went from the positive wire-Resistor-coil. And then negative from the points dist. Now I have a MSD Blaster coil. Do I still need that resistor? Do I need the white thing on top of the yellow thing?
Old Jul 24, 2002 | 01:28 PM
Twin_Turbo's Avatar
Twin_Turbo
Default Re: Ignition problems...Resistors... (Aaron-74)
Uhm, the white thing above your yellow coil is the ballst resistor.
Check voltage to coil to determine if you need the resistor.
Marck
