72 HEI wiring help
So I order the motor wiring harness. Most of the accessories on the fire wall are in a box (wiper motor and such) that came with the car. I've removed the AC unit for now also. I've ordered the NCRs book, Lectric limited, AIM and Haynes. Wiring to the starter was easy enough. 12 PPL to S, 2 blk and 12 R with fusible link to center post, black to trans housing for ground and 20 yellow to R. going good so far.
Then I run into this.
OK, I read for a week and google and get a wealth ok knowledge from you guys - big thanks. I figure out that the 20 Yellow from solenoid R should go to coil positive along with 20 B P that is XLPE resistance - do not cut. It is attached to the 20 yellow that I assume comes from the solenoid R (did not un tape the harness) Also figure out that 12 R from fusible link goes to horn relay and run it correctly. However, I no longer have the original coil and points distributor.
So it is my understanding that the 20 B P (resistance wire) to the fire wall box should not go to the distributor. I read many threads about removing the 20 B P and replacing with 12ga. I am going to replace the motor (307 ci that was in the car) and don't want to remove anything from that harness block on the firewall ( I'd probably destroy a $209 harness in the process). So I read that I can run a 12 ga from the dash fuse box from the Batt. or Acc. pin to the distributor and remove the 20 B P and tape it off. So my question is where does the 12 ga from the dash fuse box go on the distributor.
I assume the red on the right is positive and the yellow on the left is negative with the black in the middle ground. I am assuming that the 20 yellow from solenoid R goes to positive (red wire on distributor cap) along with the 12ga from the dash. If I am reading this correctly, then the negative terminal from the distributor cap will ground to the motor intake manifold. But that leaves me with the black ground?? I have looked for wiring instructions on HEI on line with no success. I'm not worried about the tach at this point, I just want to get the car started. Any direction would be greatly appreciated.
Hope this helps and clears up any confusion.
The BATT terminal is on all the time.
The ACC terminal does not get power in start.
Yes, with HEI you do not use the yellow.
All bolted back up and still no power at the starter. So I trace from the ignition switch and find this clip. It has power on one terminal when key is turned to the start position. I have no idea what it connects to as I cannot find anything close by with purple - white stripe.
So I sit and scratch my head for a while. Figured I would just hard wire it directly but then check the rest of the dash wiring harness that is all disconnected as I was cleaning up the floor pans - a few before and after pics.
So I hooked the wiring harness back to the shifter on the floor hump and bingo!! Power to the starter.
Anyone know what the 12 purple connector near the fuse box connects to?? I can only assume it's there for a 4 speed car as it would be near the clutch pedal.
Did you make sure the nss switch is adjusted so it only works in P or N?
The nss switch also turns on the back up lights.
Was this car once a stick shift and it's a 72 right?
What happened to the 76?
Good start on this one
The C5 needs company
My father (passed a few years ago) with my brothers C1. Letting the professionals restore this one.
