I took off my intake manifold ( was a struggle in itself ) to find when I went to clean it up there was a huge solid carbon buildup in something that resembles a catch can riveted to the bottom
Of my 1969 l46's intake manifold . What is this ? Is this normal ? It's so solid it's very difficult to remove, anyone ever take this thing off ? Because it doesn't look like it could go back on if it comes off. Someone help!
There is a heat shield attached with drive rivits on the underside of the intake. The oil that splashes between the heat shield and the intake gets baked from the heat of the crossover passage.
What you are seeing is not unusual. It can be removed to clean things up, and as you stated, it will most likely not go back on. Most new intakes do not have the shield.
Depending on where you live, you can use the block-off plates when you reinstall the intake if you do not need the choke. Also, if you choose to use the block-off plates, be sure to wire the heat riser flapper in the passenger side exhaust pipe in the open position.
Is there a way to leave it on a clean it out ?? ( hammer and screwdriver style ) and also do you know if our intakes
Are safe to sandblast to remove the old paint etc.
Scrap off what you can get to then get it hot tanked at a machine shop. Might have to run it through a couple times. If it has paint or stains on the exposed surface glass bead or soda blast it, don't use regular media. A lot of times the same machine shop you get it hot tanked at will have the glass bead blaster. Make sure you get all the media out between the heat shield and intake (pressure washer works good). You can remove it and get replacement rivets but I have had good success leaving it on.
thanks ! what does hot tanking usually run ? or do u think it's more of something you can convince a buddy to do at a shop?
