76 w/ 350 not starting
Old Jul 8, 2014 | 04:47 PM
scorpio66a's Avatar
scorpio66a
2nd Gear
Default 76 w/ 350 not starting
I am having problems with getting spark from my coil. I will crank the engine and will only get sparks for on revolution then nothing. After about 15 minutes it will do the same thing a few sparks then nothing. I have replace the coil, pick up coil, and ignition module.
Old Jul 8, 2014 | 08:18 PM
my 76 ray's Avatar
my 76 ray
Check to see if the pink wire to the distributor cap is losing power.
Old Jul 8, 2014 | 09:51 PM
'75's Avatar
'75
Old Jul 9, 2014 | 07:51 PM
scorpio66a's Avatar
scorpio66a
2nd Gear
Default thank you
I actually found that the new ignition module I installed was bad replaced it and it starts
To 76 w/ 350 not starting
