dimmer switch
Old Jul 10, 2014 | 07:19 AM
sgt kohler's Avatar
sgt kohler
Default dimmer switch
hello ,im new here. I just purchased a 77. its in real nice condition,but needs a few things. my question is about the dimmer /turn/ wiper switch. when the tilt column is all the way up my dimmer wont work when tilted down a bit it does work. is this the normal operation? thanks for any info.
Old Jul 10, 2014 | 08:55 AM
wombvette's Avatar
wombvette
How loose is the tilt joint? No its not normal.
Old Jul 10, 2014 | 11:09 AM
Slotehog's Avatar
Slotehog
You may need to adjust/tighten the dimmer switch located on the bottom of the column under the dash. A rod runs the length of the column from the turn signal lever to the switch. It may have come loose over the last 35+ years.
Old Jul 10, 2014 | 11:23 AM
sgt kohler's Avatar
sgt kohler
I checked the play in the tilt column and it seem to be tight. when you move it into different positions it locks in. but the tilt lever parts that I can see are sloppy back and forth. is this something that can be tightened up. I will look on the bottom of the column to see if the dimmer needs adjusting. since my wiper / turn signals/ and dimmer are all on the same lever is there just one replacement part or several for each function? thanks
Old Jul 10, 2014 | 09:17 PM
wombvette's Avatar
wombvette
The dimmer switch is near the bottom of the column. You might need to tighten up on it a little bit, however, do you really care if it is not working at max height? Do you use it up there?
Old Jul 10, 2014 | 10:54 PM
69Vett's Avatar
69Vett
Corvette of the Year Winner 2017
2016 C3 of Year Finalist
Dimmer switch has adjustment for mechanical travel,
loosen and adjust until it works in desired location, lock it back down.
Old Jul 11, 2014 | 07:53 AM
sgt kohler's Avatar
sgt kohler
im going to get under the column and check it out this morning. thanks for the info.
Old Jul 11, 2014 | 09:03 AM
69Vett's Avatar
69Vett
the dimmer switch is actually located on the top side,
right next to the iginition switch, you probable need to lower the column to access.
lossen bolts, and slide the switch towards the steering wheel.
Old Jul 11, 2014 | 12:17 PM
sgt kohler's Avatar
sgt kohler
I found it and fixed it! just need to adjust it a bit and works like a charm!!
To dimmer switch
