Replacing the Q-jet with a Holley 4165 and am wondering in advance if the OEM Pump-to-Carburetor fuel line will fit, as far as the fitting's thread size is concerned.
TIA.
Steve
If this is the Holley spread bore replacement for the Q-Jet, I would personally re-think what I am doing. Send your Q-Jet to Lars and have him set it up correctly.
I have done the Holley replacement and the Q-Jet is a better deal.
Thanks for the response Phil.
Q-Jet is on another engine. And it's working perfectly.
Holley is going on a 383 w/OEM Fuel Pump and Edelbrock Performer Manifold.
Question is: Are the carb fuel line IN thread size the same for both carburetors? I want to order the right size Pump-to-Carburetor fuel line for this engine.
