Aftermarket Starter wiring question
Old Jul 15, 2014 | 07:05 PM
wilcar's Avatar
wilcar
If you run a mallory unilite dist you need to run a ballast resistor, as per a mallory tech rep I spoke to. You will then need the yellow wire. I ran a unilite for several years without the resistor with no problems but then was told to run one. I called mallory and was told to run one.
