Borgeson frame twist
Old Jul 16, 2014 | 04:27 PM
manfroni's Avatar
manfroni
Default Borgeson frame twist
The steering issues continue. After having the new front suspension checked and realigned again, the teck mentioned that the frame where the Borgeson box is mounted "moves" under steering load. It isn't a lot, but is still moves. Has anyone else experienced this? Would that small movement cause the slop[ I feel in the steering? The frame has 0 rust and I cant see any cracks.
thanks,
Old Jul 16, 2014 | 05:14 PM
ignatz's Avatar
ignatz
Well mine does too. Probably the same thing is happening on the other side (equal and opposite forces etc) although I never thought to look. I never looked at the stock setup either so I can't compare but it has to push against something.
This is also a function of caster and camber. As I recall the car goes up and down a little bit when you turn the wheel. So that is lifitng a considerable weight.. I'd have to go out and look to verify and right now other things are taking priority.
I don't think this contributes to very much slop. I rejected the rag joint that Borgeson supplied in favor of the stock rag joint. Maybe you didn't? The former seemed too rubbery to me.
Old Jul 16, 2014 | 10:27 PM
Roadster71's Avatar
Roadster71
thanks,
I'd take another look at all the new and old steering gear. Sounds like something is loose or worn. My Borgeson unit has very little if any slop. Have someone turn the wheel while you watch the steering shaft and pitman arm. They should both move at the same time. If they do then the problem is in the steering gear. Another possibility could be the wheel bearings.
Old Jul 17, 2014 | 01:50 AM
mac79vette's Avatar
mac79vette
I have no play in the steering and I have a borgeson box. My frame also moves a little, looked at my Chevy 1/2 ton and 3/4 ton trucks and there is more movement than the vette. So I would say this is normal and the problem is something else.
Old Jul 17, 2014 | 07:18 AM
manfroni's Avatar
manfroni
No rag joint, replaced it with the Borgeson universal. I will check to see if the pitman arm moves with the steering wheel / output shaft on the box.
Old Jul 17, 2014 | 01:46 PM
ignatz's Avatar
ignatz
idler arm OK?
Old Jul 17, 2014 | 07:02 PM
manfroni's Avatar
manfroni
Default Dumb ***
What a dumb *** I am, after 3 trips to the alignment shop and hundreds of dollars I found the problem. I never tightened the set screws on the universal joint. Now it really drives well. At 57 years old I should have known better!
Old Jul 17, 2014 | 09:14 PM
SHARKBIT77's Avatar
SHARKBIT77
Good to hear you found the trouble. The box on my 77 vet and my sons 81 camaro also move a small amount. I think your ok there.
Old Jul 17, 2014 | 10:16 PM
Roadster71's Avatar
Roadster71
Wait another 10 years, it gets worst.
To Borgeson frame twist
