Dart head install
Old Jul 19, 2014 | 04:52 PM
hamck's Avatar
hamck
I never mentioned 700 ft man you guys are sharp! I'm around 700 at the house, everything's up hill from there.
Old Jul 19, 2014 | 08:42 PM
63mako's Avatar
63mako
St. Jude Donor '08-'09
Originally Posted by hamck
OK I crudely C/C one combustion chamber today and came up with 65 C/Cs
With .040 qu. i'm at 8.55 DCR. With a.021 gasket qu. at.046 and DCR of 8.43 .
I'm using one of the online calculators so who knows how close it really is. Either way i'll need hi test. If this stuff was easy,it wouldn't be fun. Thank you gentlemen
You will be more detonation resistant @ .040 than bigger quench even though the DCR number is over 8.5. Best option is going with a Lunati 262 cam, http://www.lunatipower.com/Product.aspx?id=2324&gid=287 If you can afford it you can add noticeable power across the board with no loss in streetability with this:http://www.lunatipower.com/Product.aspx?id=4576&gid=289 Either will work great with your compression ratio, gears and stock 2000 RPM convertor.
Old Jul 19, 2014 | 09:42 PM
augiedoggy's Avatar
augiedoggy
I went with the lunati 262 cam for this exact reason. It allowed me to use flat tops with 64 CC iron heads and a .37 quench.
