Upper Control Arm Bumper
Old Jul 18, 2014 | 06:10 PM
kjr6306's Avatar
kjr6306
Default Upper Control Arm Bumper
I just finished putting my front control arms back together with new bushings, ball joints, springs and shocks. After admiring the finished job for a few minutes I realized I forgot to put the new upper bumpers on....wth??? Can I get these put on once I put the engine back in and get some weight on the suspension or should I bite the bullet and take off the upper ball joint and put them in now. P.S. the springs were a PIA due to no weight on the suspension....
Old Jul 18, 2014 | 06:30 PM
Mooser's Avatar
Mooser
Just checked, with the engine etc in I can pass my fingers between the bumper and the upper control arm.
It'll be a PIA to manipulate them into place but you should be able to pop them in (they go in fairly easy especially with some white grease on the nub part)
Or, wait until the motor is in and with a jack under the lower arm, disconnect the upper and make it easy
M
Old Jul 18, 2014 | 08:13 PM
72LS1Vette's Avatar
72LS1Vette
Wrap a piece of twine around the narrow part of the bumper and feed both ends up through the mounting hole. Apply some upward pressure to the mount and pull on the twine. It should pull the tapered end up through the mounting hole and allow the bumper to seat properly. I didn't invent this technique and I forget where I saw it but it works like a charm.
Rick B.
Old Jul 18, 2014 | 10:12 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
I did this once.. on a body off job..
I just installed the "home made" spring compressor.. and it raised the upper arm enough that I could install the upper bumper.
http://repairs.willcoxcorvette.com/c...r-on-a-budget/
Old Jul 19, 2014 | 12:25 AM
kjr6306's Avatar
kjr6306
Will try the string trick......you guys are the best.!!!
Old Jul 19, 2014 | 09:02 AM
PHIL 68's Avatar
PHIL 68
I did same thing last week but sadly never thought of string so I removed spring again so I could get pliers on rubber to pull down all back together now. Seems like I do a lot of jobs twice. Phil
Old Oct 19, 2015 | 02:16 PM
RelativeEarth's Avatar
RelativeEarth
Cruising
With spring out and control arms pushed away. I lubed rubber bumper and hole with dish soap. Using a 6 inch C clamp and 1 1/8 inch socket I was able to press it into the frame. (socket is underneath in spring tower) Put soap on all mating surfaces where bumper meets frame because you will need to rotate the C clamp back and forth. Without enough soap, the bumper will not spin on the frame which is necessary to get the nipple in the hole. Pressure alone did not work for me on my 68 corvette.
To Upper Control Arm Bumper
