Factory tach accuracy?
Old Jul 21, 2014 | 12:48 AM
bluedawg's Avatar
bluedawg
Default Factory tach accuracy?
I recently goofed and trashed my factory tachometer, so I bought an auto meter digital tach with a shift light and peak rpm play back. Wasn't so keen on the digital aspect but the shift light and playback features are nice. The question is it seems like I wind a little higher to hit 6000 rpms and I've checked the tach with my timing light, which they were spot on with each other, so do you think the factory tach was off and if so by how much?
Old Jul 21, 2014 | 07:26 AM
OzzyTom's Avatar
OzzyTom
Factory tach was most likely inaccurate.
When I checked my tacho for accuracy a few years back it was reading about 1000 rpm low... That solved the mystery as to why I was bending pushrods at only "5800" rpm.
I pulled out the dash and had the tacho and speedo overhauled and calibrated. Both are accurate now.
Old Jul 21, 2014 | 08:49 AM
BKarol's Avatar
BKarol
When I went on the dyno I noticed my factory tach to be off @200rpm. Installed an Autometer on the column and appears correct now, so not so bad.
Old Jul 21, 2014 | 12:10 PM
7t9l82's Avatar
7t9l82
whats accuracy? with a factory tach. not even a good guide.
To Factory tach accuracy?
