Hey all. Trying to figure this one out. I've been blowing fuses like crazy. Something happens where the horn sins then the fuse blows, then I have no brake lights. Anyone experienced this? Don't like driving because I never know when my brake lights will work. Could really use a hand here, speed to take a drive to Milwaukee with the wife this weekend and I'd love to take the Vette. Hope I can get some ideas here
This is an 81, right? It's probably wired the same as my 78. Horn and stop lights on the same fuse. I had this same issue. One of my horns was dead.
I troubleshooted it by unplugging the horns one at a time. With one horn disconnected, I got a honk. With the other horn disconnected, I could only hear the relay click. So that horn was dead and was drawing enough amps to kill the fuse when both horns were connected. You could also have a short in the wiring.
I had the pair rebuilt by "The Horn Works", they did a great job. Alternately, you can purchase replacements.
My horn didn't work til I replaced the rag joint... Either from me completing a ground through the joint... Or manhandling the column when I pulled it back to separate the two for RnR... Could always trace to a ground issue somewhere if it isn't what shark described...
Never even thought of the horns not working! So I'll have to test them. Not a lot of time to track down shorts or anything, I'm leaving Friday morning! It would be really nice to be able to drive it this weekend
Don't forget to check the horn relay. Caution; it's always hot from the battery. It could be shorting out inside, so if it's original, just replace it.
If this was the case the circuit wouldn't close and neither the horns nor the fuse would blow.
