Gears for a street driver
Old Jul 29, 2014 | 12:08 PM
  #61
Priya's Avatar
Priya
Before all the resale arguments start, doubt it would affect it one bit. fact Id pay more for a well done OD car
I feel the same way.
Old Jul 29, 2014 | 12:20 PM
  #62
BlackC3vette's Avatar
BlackC3vette
x2 on not doing the 3.36 youll never notice it
Went from 3.08 to 3.73...noticebale under most driving not what I thought. WOT it was better, course fwy rpm was up there
Finally went 4.11, now that I could feel. Added an OD trans best thing I ever did.
Sure hated paying for it but the first time I drove it and got it on the fwy had a big old smile.
It seems like opening pandora$ box but you will want to drive the car more, farther etc. Will pull hard and be easier on gas.
With the 4.11's, was the OD a 6 speed?
Old Jul 29, 2014 | 01:00 PM
  #63
AboveTheLogic's Avatar
AboveTheLogic
For the record, I've been dreaming about a T56 6-speed / 4.11:1 gearing ratio setup for quite some time now. I did recently have my rear end rebuilt, but left in the same gears. I'm hoping that a gear swap in the future wouldn't be a big deal. We'll see if I can ever manage to find a T56 at a reasonable price, they are commanding a lot of cash these days.
Old Jul 29, 2014 | 07:11 PM
  #64
71454Chevelle's Avatar
71454Chevelle
I am running a Tremec T-56 Magnum in my Chevelle. It has the 2.66 low gear and IMO works very well my 4.56 gear and 30 inch rear tires. If I was running a shorter tire, I'd probably go with a 4.10 or 4.30.
As far as this OD transmission, I love it. This thing changed the whole characteristics of the car. Driving on the interstate is actually pleasurable. Even with the 4.56 gears, in 6th gear, it cruises nicely at 70 mph at a little over 2200 rpm. It's fully syncoed, shifts like a dream, very positive and has no issues shifting at 7000 rpm. I can't remember ever missing a shift with this thing.
Some wonder why do you need 6 gears? With a 5 speed, the 5th gear, IMO is either too tall and a huge rpm drop between 4th and 5th, or not tall enough, which means turning more rpm's on the interstate than you want. The beauty about the 6 speed is 5th gear is like an "in-between gear". I use 5th in what I call "back road" speeds, 45-60mph. 6th gear is for the interstate; 60+ mph. 5th gear is .80 ratio and 6th is .63.
Old Jul 29, 2014 | 07:27 PM
  #65
cv67's Avatar
cv67
St. Jude Donor '05
yes, T56 out of an LT1 F body
If you run a mild motor perhaps a little less gear will do ya
My car could probably use a 4.30 or 4.56 due to the size of its cam but get by with a short tire
5th on the fwy at 65 puts the motor in its sweet spot I actually enjoy hearing a little rpms at cruise. If I want 6th go a little faster and cruise around 2300. I use a 26in tall tire.
Think most cases a 5 spdwould be enough
Old Jul 29, 2014 | 07:50 PM
  #66
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
Careful not to end up with 1st being somewhat of a granny-low gear. I ran a 1st ratio of 14.14:1 (3.44 x 4.11) in a C3 for a short time, and can promise you that anything close to that sort of range is heading into dump truck territory for most street or any AX/RR type use.
As for a 5-speed with tall 5th vs 6-speed with stronger 5th plus a cruising only gear, the latter is probably the better compromise between the two. Yes, there's the extra weight thing, but IMHO having a big step from 4th to 5th isn't going to quite satisfy if you want to keep having some fun after 4th gear runs out. (I hate when that happens.)
FWIW, of the typical street 5's and 6's out there (without endorsing any particular one), something along the lines of the TKO-600RR or Richmond SS 5 w/OD would happen to best suit my own trackday oriented purposes, but I'm leaning heavily towards just doing a racing dog box (non-syncro) next.
Old Jul 30, 2014 | 01:11 AM
  #67
BlackC3vette
The 3.73 ratio is probably the upper limit based on the cam spec's. Compcam even listed the 3.73 as the upper limit with the 3.23 as the lower limit.
Old Jul 30, 2014 | 01:52 AM
  #68
63mako's Avatar
63mako
St. Jude Donor '08-'09
3.54
Old Jul 30, 2014 | 02:23 AM
  #69
Shark Racer's Avatar
Shark Racer
Originally Posted by Priya
My 70 Torino originally had a 3.00 rear end. I went to a 3.89 rearend and thought there was very little difference between the two. Later I swapped the 22 inch tall rear tires for 28 inch tall which was essentially the same as switching back to a 3.00 rearend and I felt like it was a huge difference in acceleration. So, for me whether or not switching 3.89 and 3.00 rear gears had a noticeable effect depended almost entirely on which way I was going.
The numbers work out very closely between the two (about a 1mph difference at 2000 rpm, 3.89/28" vs 3.00/22") but you have to remember that the 28" tires come with the added penalty of reciprocating mass. You now have mass extended at a 3" further radius than before and more mass overall as well.
But I think your point still holds... it's always hard to go "the other way".
Old Jul 30, 2014 | 11:29 AM
  #70
BlackC3vette
Originally Posted by 63mako
3.54
3.54 would put the rpm's at 70mph at about 3300 (T10). The 3.73 would be at around 3500 rpm. With the original 3.08, it's turning about 2900 rpm, so the 3.54 is not really going to make it scream on the highway. Anyway, its not like the gears are welded in! As usual, your recommendation is well thought out.
