balance rotating assembly or no?
im using the the stock crank and the rods are standard length and the pistons 4.000 bore. if i should get it balanced what is a good price to pay for it?, ive talked to one shop here in tampa and they wanted $350.
t.l.d.r- should i get the rotating assembly balanced and whats a good price to pay for it?
Hate to turn the same bolt twice needlessly.
The point of all of this is that the level of balance is most directly related to the amount of power it requires to spin the rotating assembly at any given rpm. The better the balance, the less horsepower required to spin it. If your particular engine produces 350 horsepower on an engine dyno and also requires, say 50 horsepower to spin the assembly at 5,000 rpm, it is actually producing 400 horsepower, but only 350 is available for your use. If you can reduce that amount from 50 to say 40 that extra 10 horsepower is now available for your use.
In the past, "most" manufactures have really only been concerned with engine balance as it related to destruction within the warranty period. Today as fuel mileage has become a prime concern (CAFE), you're seeing more and more manufacturers using things like synthetic oil, roller bearing rotating assemblies and yes paying more attention to internal balance, to increase fuel mileage by reducing the parasitic or induced drag of the rotating assembly.
So the next time someone asks if balancing an engine is necessary, don't forget to factor in the horsepower (and yes economy) that might be lost if they decide it's not necessary.
Good luck... GUSTO
There is no way the 2nd rebuild @ 114,000 miles will get by with standard bore.
Good luck... GUSTO
If the balance isn't important then there wouldn't be any reason to balance any part of it. Dealing with degree of out of balance is in relation to the RPM. as the rpms increase the effects of out of balance increase. Take a window fan and put a little lead tape on one blade and run it on slow. You'll see the vibration created. Increase the fan speed to high and the vibration increases in proportion with the increase of the blade speed. The distance of the over weight from the center line of the crank has a similar affect.
you can weight your old pistons and rods and see it will be close or you could just chance it by not balancing.
