Will it start hot?
Old Jul 28, 2014 | 12:12 PM
GearDrive65's Avatar
GearDrive65
Default Will it start hot?
I just installed a dual electric fan setup in my big block C3, and haven't ran the car yet.
I hooked the thermostatic switches 12v to pos. side coil.
The 12v side relay to back of alternator.
This setup will allow the fans to run as soon as I turn the key on with the engine up to temp.
Will the fans draw too much amps to not allow the starter to crank properly?
Do I need a manual override switch on the relays?
Old Jul 28, 2014 | 01:16 PM
69Vett's Avatar
69Vett
Corvette of the Year Winner 2017
2016 C3 of Year Finalist
you have to add up the current draw of the 2 fans,
your gonna draw excess current thru your inginition wiring,
I would not recommend wiring this way.
now you could add a relay for the gnd using the coil as a signal.
this would avoid extra current draw thru your igniion coil power/gnd.
Old Jul 28, 2014 | 01:21 PM
GearDrive65
The ignition will only have the draw to signal the relay. The fans will draw off the alternator.
Both fans together draw 37.5 amps.
Old Jul 28, 2014 | 03:19 PM
69Vett's Avatar
69Vett
using the iginition 12v to operate the relay should be ok.
To Will it start hot?
