Build thread: LSx 6.0 swapped c3
Old Aug 2, 2014 | 12:33 AM
Planbmatt1's Avatar
Planbmatt1
Default Build thread: LSx 6.0 swapped c3
Well last week I picked up my new 1976 red stingray. It has 39k miles and a new l82 built. Drove it home two hours and parked it. Ive been debating on doing a weiand 142 etch but here it is. Final decision on build. I ran into a big raise at work and income is flowing nicely soooo
My friend has the following brand new parts.
lq9 6.0 short block
timing gears
oil pump
roller rockers
push rods
he is trading me all of this for my turn key SBC. I have already ordered
ls1 intake
lq9 heads
lq9 valve covers
ev14 injectors
corvette fuel rail covers.
I still have yet to decide/order
Lq9 cam
F-body oil pan
motor mounts (adjustable or fixed)
closed loop ECU wiring plug n play
Msd fuel system
F-body motor accessories
Dewitts custom radiator
lsx swap headers
I have a guy who does lsx swaps for a living and builds them helping me. (same guy who had the spare LSx sitting around brand new)
the motor and transmission come out Sunday. We also start building the 6.0 also on Sunday. This will have tons of pics.
Old Aug 2, 2014 | 01:10 AM
bluedawg's Avatar
bluedawg
Nice. I'm more of a tradition small and big block for my vette. But what your doing is the way to go if your into that. Power, fuel economy and longevity. Add forged pistons, a supercharger and the right cam and it will scream good luck and you know the rule, updates with out photos didn't happen.
Old Aug 2, 2014 | 01:19 AM
Planbmatt1's Avatar
Planbmatt1
Sunday ill have photos of the new 6.0 short block and bay cleaned out
Old Aug 2, 2014 | 01:22 AM
Planbmatt1's Avatar
Planbmatt1
I paid $500 for all new engine stands, cherry pickers, and a racejack just for this swap.
Old Aug 2, 2014 | 07:18 AM
7t2vette's Avatar
7t2vette
The ORIGINAL and bestest
Toronto Events Coordinator
I am looking forward to following the build.
Old Aug 2, 2014 | 08:16 AM
Garys 68's Avatar
Garys 68
If you're upgrading the cam, you'll want an LS6 intake.
I'm running an LQ9 in my 68 with an LS1 intake and stock cam. But I suspect the intake is at it's limits at around 350-400hp.
Old Aug 2, 2014 | 08:19 AM
minitech's Avatar
minitech
For me the deal would be we swap the engines the exact same day. That way I keep driving until he delivers the running product. Not to say there will be a delay but there can be and you are then not driving your car.
Thanks for doing the write up, will be nice to see!
Old Aug 2, 2014 | 08:30 AM
tt 383's Avatar
tt 383
I support the swap but as mentioned, not the intake. They are a little taxed at 400hp, though thats at the wheels. For simplicity to get it going though it is ok I guess. The fast 92 would be a "direct" ls1/6 swap minus the tb, a 102LSXr or even better the 102LSXrt would be best for a 6.0 thats cammed with decent heads. Maybe I missed it, but what heads are you using? Nevermind, see its the lq9. If they need freshened Advanced Inductions has great programs for stock heads, and do chamber welding to bump compression for very cheap. I believe they are basically ls6 castings with bigger chambers.
Old Aug 2, 2014 | 09:14 AM
tt 383's Avatar
tt 383
Sure your buddy knows this but dont be afraid of a healthy cam, its not quite like a sbc in that regard especially with a 6.0 and some compression. Ls1tech is a great site to do research for anything ls in general.
Old Aug 2, 2014 | 09:24 AM
Planbmatt1's Avatar
Planbmatt1
I have decided after talking with him that I will run just a stock lq9 cam with the ls1 intake. Also using a msd inline fuel pump and a regulator to keep it simple. I want to get it purring like a kitten before I do cam heads etc.
Also all parts he brings me are BRAND NEW
it will be far from running Sunday. I'll need radiator from DeWitt, flywheel adaptor, f-body oil pan and full accessories, wiring harness, etc
Old Aug 2, 2014 | 09:49 AM
Garys 68's Avatar
Garys 68
My plan was cam, L92 or LS3 heads and intake. But after running the Stock heads/cam with a Richmond 6 speed, I realized it would overpower my stock tires pretty easily. You'll be happy with the stock power especially after running a SBC.
I wouldn't suggest raising the compression any if you're having head work done. On hot days, driving hard, you can feel the spark retard once the knock sensor pick up pinging.
Old Aug 2, 2014 | 09:55 AM
Planbmatt1's Avatar
Planbmatt1
Exactly. The power is gonna be plenty for a weekend show car. Also what head work on a new lq9 head would need to get done to run these expensive as hell rollers i got for free. Aluminum 1.7 ls roller rockers.
Old Aug 2, 2014 | 10:05 AM
Garys 68's Avatar
Garys 68
Nothing, the 317 heads flow really well and your cam (LS1 cam) would be restricting hp anyway.
Old Aug 2, 2014 | 10:22 AM
Planbmatt1's Avatar
Planbmatt1
Perfect. You guys have a link to get stock valve covers off a lq9? Will ls bolt pattern valve covers work?
Old Aug 2, 2014 | 10:29 AM
Garys 68's Avatar
Garys 68
My suggestion would be to get a junk yard pair off a truck, 5.3 or 6.0, with coils attached. The coils are pretty expensive to buy new.
Old Aug 2, 2014 | 10:54 AM
Planbmatt1's Avatar
Planbmatt1
How do ls1 heads compare to lq9?
Do the valves clear the pistons?
Old Aug 2, 2014 | 12:57 PM
Garys 68's Avatar
Garys 68
Not sure if the LS1 heads would work well, if at all, with the larger bore LQ motor. Save yourself headaches and stick with the stock parts.
To Build thread: LSx 6.0 swapped c3
Old Aug 2, 2014 | 04:35 PM
Gordonm's Avatar
Gordonm
But after running the Stock heads/cam with a Richmond 6 speed, I realized it would overpower my stock tires pretty easily. You'll be happy with the stock power especially after running a SBC..
Never enough power. My LS 3 will be over 500 NA HP and I have only driven it around the block. Gobs of power but already thinking of a maggy supercharger
Have to get it on the road first but yes the LS motors put out gobs of torque.
Old Aug 2, 2014 | 06:34 PM
Planbmatt1's Avatar
Planbmatt1
Forced induction is so full of headaches but so worth it lol ill be using a f-body for all accessories and oil pan. I have the motor all figured out. Ill be running the msd fuel set up with corvette regulator. Painless is doing my wire harness. Its pretty much plug n play from there. My guy is getting the lsx adaptor to th350 for me. Motor mount adapter plates are ordered. The only part i havent figured out yet is throttle body. Its my understanding ill want drive by wire?
Old Aug 2, 2014 | 07:10 PM
Gordonm's Avatar
Gordonm
I am running drive by wire. Just using the C6 pedal assembly that can be found anywhere. Using the stock LS 3 throttle body. Easy to fab up.
