New Moog K6034 Upper Ball Joint Correct Installation Procedure
Sorry if this is an obvious or stupid question, but about to install my upper ball joints, which I purchased K6034's from rock auto, and I am not clear (based on the crappy instructions provided) the correct order of installation.
I have the ball joint, the boot and a metal sleeve (as well as a bag of hardware).
Tying to determine in what order they should be installed.
Should the ball joint be installed from the top, then slide the boot over the spindle from underneath, then the metal sleeve over the boot?
I have searched the threads, and I dont see this very clearly in the replies.
Thanks for the help!
I forgot to reply back to this, but just in case it will help someone else in the future.
I called Moog about this, and the tech gave me specific instructions on how to properly install the boot. His explanation was that the rubber boot gets pushed inside of the metal sleeve so that the lip of the boot catches on the lip of the metal sleeve.
