1/4 mile time
Aug 6, 2014 | 05:07 PM
Cruising
1/4 mile time
What would mine be, 383 375rwhp, 370ish torque, turbo 350 with shift kit, 3000 stall, would I be in the 12's, your thoughts
Aug 6, 2014 | 05:26 PM
Quote:
Originally Posted by
Floatplanepilotguy
I'd think you'd be in the 12's, with every thing working such as traction, gearing ect. Might even be better.
Aug 6, 2014 | 05:45 PM
Altitude is a big factor. Where I live at 6000ft it would be mid/high 15's.Sea level 12's depending on your rear end gearing.
Aug 6, 2014 | 05:52 PM
no way a 3 second difference.
Aug 6, 2014 | 06:01 PM
Yes way! Cant find the formula right now but its about 4-5%HP loss per 1000 ft in elevation.
Aug 6, 2014 | 06:06 PM
Aug 6, 2014 | 06:22 PM
Cruising
3.55 gears, good tires, I'm thinking low 12's, middle 11's if I can get hp over 400 at wheels, I'm at 900ft above sea level
Aug 6, 2014 | 06:26 PM
i think you close, there are variables involved. but your realistic.
Aug 6, 2014 | 07:16 PM
Only one real way to find out.
My 76 vette with 468 BBC maxing 520 hp at crank, th350, 3.36 gears, 3200 stall ran 11.60s to 11.80s.
I would think you would run low 12s, just a guess.
Probably 50 ft above sea level.
Take her to the track and let us know.
Roger
Aug 6, 2014 | 08:57 PM
my std. bore 350 in my 82 with a small flat tappet hyd. cam and th. 350, 3000 stall 3.36 gears on pep boys radials. having to leave easy to avoid spinning. runs consistent 12.20s and a 12.18 best. avg. mph 109-110. best was 111mph. you should be low 12s on a bad day
Aug 6, 2014 | 09:39 PM
are yuo talking ideally or what can you expect to see on a slip?
Aug 6, 2014 | 09:53 PM
My 383 with 373 rwhp ran 11.62 in the 1/4 mile. I had a 3000 stall converter, Turbo 400, shift kit, and 4.11 gears.
