Heat Barrier Kit?
Old Jul 26, 2002 | 06:57 PM
gmcclurg's Avatar
gmcclurg
Default Heat Barrier Kit?
I am starting to think about working on the interior and getting my Carlisle shopping list ready. I will be replacing the carpet and would like your thoughts on the heat barrier kits offered to go under the carpet - "ceramic cloth with foil backing" ??
Gil
Old Jul 26, 2002 | 08:13 PM
mrvette's Avatar
mrvette
Default Re: Heat Barrier Kit? (gmcclurg)
IMO, better off with a cheap foil backed roll of hot water heater wrapping cut so size, and it's only 1/2 inch thick fiberglass, will compress easily...
put glass to glass, and foil to rug....works well...
GENE
Old Jul 26, 2002 | 10:09 PM
GTR1999's Avatar
GTR1999
I got a roll of aluminum foil roof insulation 1/4" thick at Home Depot. I didn'ruse it yet but gave it to my buddy who used it in his 62. He said it made a big difference. Cost about $45 enough for 2-3 C3's.
Gary
Old Jul 27, 2002 | 08:16 AM
jerryp58's Avatar
jerryp58
I used a pre-cut kit.
It was fine, but if I ever do that job again, I'll just buy a roll of the insulation material and fit it myself.
The kits are pretty pricey compared to the bulk material and, even though they may not have needed insulation, the kit left some bare spots that I would have liked covered.
Old Jul 27, 2002 | 08:51 AM
jimvette999's Avatar
jimvette999
Default Re: Heat Barrier Kit? (jerryp58)
I used JC Whitney roll stock of heat/sound barrier and it made a big difference. Not cheap and I went all out insulating every avail. surface while I had interior out. Some areas two layers used like trans. tunnel.
Good luck.
:seeya
Old Jul 27, 2002 | 03:34 PM
glen242's Avatar
glen242
Default Re: Heat Barrier Kit? (mrvette)
GENE
I thought the foil was to reflect heat back to where it came from? Heat comes from underneath the car, so shouldn't the foil be towards the floor?
Please correct me if I am wrong.
Old Jul 27, 2002 | 05:21 PM
Geoff1340's Avatar
Geoff1340
I just finished my 77 and man did it make a difference!!! Used JC Whitney and HomeDepot stuff and insulated the @#$%*&! out of it!
Old Jul 27, 2002 | 10:39 PM
dlw's Avatar
dlw
EZ COOL insulation! Its 1/8" thick, foil on both sides, used in NASCAR, and its only 30 bucks or so for a 4x8 sheet. Call: 717-624-3581.
I used it under my carpet and it cut the hot foot heat by at least 70%.
Folds easy cuts easy. Tape seams with aluminum tape and badda bing.
(man, I should get a kick back from these guys) :D
Old Jul 28, 2002 | 12:19 PM
no_radio's Avatar
no_radio
I used the pre-cut mail-order kit. It was the foil-backed ceramic cloth, but I forget whether the aluminum goes up or down, down I think...
There were alot of gaps, so I cut some additional insulation material I had lying around and filled in everything, including under the seats, and heavy over the trans tunnel. Then I taped everyseam with aluminum furnace tape. Really helped cut the heat and noise level. I liked the kit because it saved some time, but you could do a really good job without it as well. Also, don't use the foil with air bubbles under your feet, the bubbles will break down and there went your insulation with it...
Jeff
Old Jul 28, 2002 | 01:13 PM
Nomad78SA's Avatar
Nomad78SA
Default Re: Heat Barrier Kit? (no_radio)
I am getting ready to do this on my vette after I get the body on seeing how it is gutted now. I will have to go and look at some of the suggestionngiven and check the prices.. I do know from past post that the heat barrier kits are not the way to go.
Neil in Tenn
Old Jul 28, 2002 | 01:52 PM
BobJ's Avatar
BobJ
Default Re: Heat Barrier Kit? (Nomad78SA)
I'll DEFINITELY be doing this soon. Had my car three weeks and I can barely stand to drive it once it's up to operating temp. I was going to buy a kit but after reading this I think I'm heading to Home Depot!!
Thanks, good info..... :cheers:
Bob
Old Jul 28, 2002 | 01:56 PM
MIKER's Avatar
MIKER
I used aluminum tape on the bottom of my car to reflect/reduce the radiant heat. I really wish that I had some solid "before and after" interior temperature data to share but I don't. I can only say that I definitely believe that it helped.
My floor board temperatures aren't bad now but I will also install additional insulation when I replace the carpet.
Radiant heat transfer. My attempt to reduce it.
http://forums.corvetteforum.com/zerothread?id=303798
[Modified by MIKER, 11:57 AM 7/28/2002]
Old Jul 28, 2002 | 02:00 PM
gmcclurg's Avatar
gmcclurg
Default Re: Heat Barrier Kit? (BobJ)
Thanks for the all the response and the good suggestions
Old Jul 29, 2002 | 10:34 PM
Markm10431's Avatar
Markm10431
Parrothead
St. Jude Donor '08-'09,'13, '14
I wonder where I can get that composit stuff they use on the Shuttles? :D
Old Jul 29, 2002 | 10:37 PM
Markm10431's Avatar
Markm10431
Parrothead
Think using some of that stuff in the engine bay on the firewall would help? think it would be more trouble than it's worth?
Old Jul 30, 2002 | 11:48 AM
vettfixr's Avatar
vettfixr
I used a product from Jegs/Summit called the Super Insulator. Go to my website for the whole story at http://users.snip.net/~vettfixr/page14.htm
or take a look at the following pictures
The only problem I had was dealing with the thickness of the insulation. It makes getting the consoles back in and aligned a little tight but it's doable. Good luck.
Old Jul 30, 2002 | 11:48 PM
majbillgsd's Avatar
majbillgsd
Glad you brought this topic up. Has anyone used the combination heat barrier and sound deadner kit. This is the kit that has rubber sound deadner and the heat barrier insulation combined as one unit. It is bought in pieces just as the heat barrier insulation is in kits from Ecklers, Mid America, etc?
Bill
Old Jul 31, 2002 | 08:05 AM
Graemeinvette's Avatar
Graemeinvette
Default Re: Heat Barrier Kit? (majbillgsd)
Probably the easiest way to reduce the heat is to wrap your headers with the heat wrap tape that you can get from Ecklers etc, its also good for wrapping around the pipes near your f'glass rear spring (if fitted) to stop the heat de3laminating it. Mind you if you have those fancy chrome headers you probably dont want to do that, but all that insulation cuts down space in hte footwells. :cheers:
To Heat Barrier Kit?
