Steering frustration
Old Aug 7, 2014 | 10:08 PM
Today's problem is..'s Avatar
Cruise-In VI Veteran
St. Jude Donor '09
Default Steering frustration
Hello all,
I am looking for insight into a steering play problem that I have been unable to solve. To date, my front suspension has been rebuilt, twice actually, as the first 'kit' I purchased were subpar parts. All high quality components have been used since. I have approximately 3 inches of play total at the steering wheel. All bushings, ball joints, tie rods and wheel bearings are free of play. The play can be felt at idle sitting still, and driving at speeds above 40 mph through a gentle curve is unnerving. My steering box has been rebuilt by a highly respected builder, flexible coupler replaced at the same time and responds instantly to steering input. I feel the play is at my power steering control valve, but am hesitant about throwing yet another part at this problem. The current valve was rebuilt by lonestar caliper and has approximately 7000 miles on it. I see a slight amount of play at the valve while the steering is moved with the engine running, but have been told repeatedly, the valve cant cause this much play. The steering has never felt right during my ownership and has only gotten mildly better with each attempt to remedy the problem, but I've yet to find the culprit. Any ideas?
Old Aug 7, 2014 | 10:27 PM
wombvette's Avatar
wombvette
Originally Posted by Today's problem is..
Hello all,
Now you should be able to isolate a 3 inch play pretty quickly.
If what you say is true and all of those things are new, with a good alignment, I would first check the balance of the steering valve.
Old Aug 7, 2014 | 10:53 PM
doorgunner's Avatar
doorgunner
2026 Loser of the Year
O.K.
Brace yourself for this: Clamp the steering shaft below the "rag joint" and above the steering box with two pairs of vice-grip pliers so that the handles are propped against solid metal to prevent the shaft from rotating in either direction. While you are watching the shaft from the pliers upward toward the firewall----- Have someone GENTLY turn the steering wheel to the left until it stops...................then to the right until it stops.
How much left and right play did the steering wheel have?
Old Aug 7, 2014 | 11:19 PM
St. Jude Donor '09
Sorry, I did forget to mention I adjusted the valve yesterday as a test. It was slightly off, but made no difference in steering feel, and I agree with you, this much play I should be able to find easily.
Originally Posted by doorgunner
O.K.
Possible play in the column itself? That thought crossed my mind, but I assumed the column was solid internally and only supported by bearings. I will do this test tomorrow.
Old Aug 7, 2014 | 11:37 PM
PeteZO6's Avatar
PeteZO6
...Possible play in the column itself? That thought crossed my mind, but I assumed the column was solid internally and only supported by bearings. I will do this test tomorrow.
The steering column is made to collapse several inches in a collision. Do a search on here or check the factory service manual where it is fully described
Possibly your problem is there.
Doorgunner's vicegrip test would tell you if the play is between the rag joint and the steering wheel, i.e., in the collapsible column.
Pete
Old Aug 8, 2014 | 12:12 AM
Peterbuilt's Avatar
Peterbuilt
Default Maybe the cylinder not the PSCV.
Have you looked at the end of the PS cylinder, there are two rubber parts and a spacer between them.
If the rubbers are worn out you will get a lot of play at the wheel.
http://www.parts123.com/parts123/yb....Z5Z50000050~~~
Old Aug 8, 2014 | 07:48 AM
Jim Shea's Avatar
Jim Shea
What year Vette? Also, you seem to imply that you have a standard (non-adjustable) type steering column? A tilt & telescoping steering column does have a couple more places (over the standard column) that could cause some looseness.
With the engine off, you will see additional play where the stud meets the control valve. That movement should basically disappear with the engine on. I am still thinking your problem is in the steering gear. On the top cover of the gear is a screw and lock nut. Are there any threads showing above the lock nut? A properly adjusted gear, (rebuilt with good or new parts) should have about three threads showing above the lock nut. If the screw is level with the nut (no threads showing) it means that parts are worn and the gear can no longer be adjusted to compensate.
Jim
Old Aug 11, 2014 | 10:24 PM
St. Jude Donor '09
O.K.
Pete
Sorry for the delay in responding, but life got in the way of my playtoy. Here is a video of the in car steering play, play viewed at the box input, and play with the column locked down with vice grips.
I did check these as well, the rubber is good and the metal sleeve to keep the bushings from crushing is in place.
Jim
Hi Jim, the car is a 1978, tilt and telescopic. The screw has about 6 threads showing above the locknut. It can be seen in the video above. The gears, bearings and bushings were replaced during the rebuild, which has about 500 miles on it now. The play on center at the box shown in the video results in about 1/16inch movement at the pitman arm, is this enough? Or should the input match the output movements?
Thanks to all for your input.
Old Aug 11, 2014 | 10:49 PM
blk79nj's Avatar
blk79nj
Nobody mentioned the idler arm or pitman arm. I assume the pitman arm was replaced when the box was rebuilt.
Old Aug 11, 2014 | 10:56 PM
St. Jude Donor '09
The pitman arm is basically just cast metal, no wearable components, so it was reused. The idler arm was replaced during the suspension and steering rebuild with a Moog part.
Old Aug 12, 2014 | 01:10 AM
PeteZO6's Avatar
PeteZO6
Pretty sure it's forged, not cast.
Pete
Old Aug 12, 2014 | 08:28 AM
mrvette's Avatar
mrvette
I remember going through all of the above some years ago, then I heard of a guy installing a rack in his car, a fellow in Europe, name of Yoshi as I recall.....so finally figgering out what rack he used, I got one from a '92 Grand Am 35 bux, junkyard find that was fresh to the car it was pulled out of, so I got a 'new one'...... I installed it and all the steering problems went away, the old setup has a lot of inherent slop in it, the box was tight, and the ratio was like 16-1 making 3.7 turns lock to lock.....the rack is 12-1 so 2.7 turns lock to lock....much quicker and tighter too boot.....I have a '78+ column in my '72 vert.....been there since '95...THAT was a fun rebuild project......NOT!!!!!
Old Aug 12, 2014 | 09:37 AM
AirborneSilva's Avatar
AirborneSilva
After reading Jim's explanation as to how many threads should be showing (and Jim does know his stuff on steering), here's what I would do... Tighten the screw down one turn at a time, testing for play after each turn, then you'll know if it's in the steering box or not and if your only doing one turn at a time then it's easy to back track
Old Aug 13, 2014 | 07:44 AM
Jim Shea's Avatar
Jim Shea
There are actually two bearing adjustments on the gear box. One is the screw and lock nut on the top cover. The other is a large stamped nut on the input shaft of the gear.
You should not see any detectable movement of the input shaft sliding in and out of the gear box housing as someone rotates the steering wheel back and forth. Any motion in and out will translate to lost motion at the steering wheel. This motion would mean that the thrust bearings are bad or the gear has been improperly adjusted.
The gear needs to be removed and readjusted by someone with an inch-lb torque wrench and other proper tools.
BTW, if you are going to play around with the top cover screw, you should make any changes by rotating the screw 1/4 turn - NOT full turns. Always make any changes with the road wheels pointing straight ahead and the gear right on center.
Jim
Old Aug 13, 2014 | 08:01 AM
augiedoggy's Avatar
augiedoggy
If the steering gear box is anything like the one on my dodge you DONT want to over adjust /tighten the screw that tightens gear mesh as it can cause the gear teeth to wear very quickly.
To Steering frustration
