Oil pan recommendation
Old Aug 8, 2014 | 04:11 PM
KJL's Avatar
KJL
Default Oil pan recommendation
Looking for a kick-out rail oil pan that will fit a C3 with a stroker motor.
Thanks.
Old Aug 8, 2014 | 04:41 PM
StraubTech's Avatar
StraubTech
Kickout pan rail or sump kickout? Sump kickouts do nothing to help with windage, pan rail kickouts do everything to prevent windage.
Old Aug 8, 2014 | 10:11 PM
C3 Stroker's Avatar
C3 Stroker
Milodon Stroker Low Profile oil pan.......that's what's on my 427sb.
This one......http://www.summitracing.com/parts/mil-30908/overview/
Old Aug 8, 2014 | 10:56 PM
gkull's Avatar
gkull
Chris posted some excellent oil pans.
In a typical you can use something like a main cap extended stud diamond scraper. if you have a stock block with big rods you have to hog the lower pan rails on the forward cylinders for big 6 inch rod bolts. Chris showed some HP gaining pans. I
Old Aug 9, 2014 | 12:59 AM
KJL's Avatar
KJL
Yes, looking for something with kicked out rails and sump. Not sure I am crazy about extended studs. Interferes with torquing the caps. Would prefer a pan mounted windage system.
Old Aug 9, 2014 | 07:44 AM
gkull's Avatar
gkull
I was hoping that Chris would show the trick pans, but anyway you might talk to these guys. The 1092# looks interesting.
http://www.kevkoracing.com/wetsump_chevy.htm
Old Aug 9, 2014 | 12:01 PM
7t9l82's Avatar
7t9l82
that pans going on mine right now , needed to do the pan gasket so the Milodon pan and a Melling select pump are going in.
To Oil pan recommendation
