LED bulbs for dash lights?
Old Aug 11, 2014 | 07:35 PM
Brians1's Avatar
Brians1
Originally Posted by havesometo
This is what I did to mine.
Love the look here!, could you expand on what brand you used, also did you use any of the mentioned dimmer "tools" or is it just lights on and full power is what we seee here ?
Old Aug 11, 2014 | 09:37 PM
havesometo's Avatar
havesometo
No I did not use a dimmer.
These are the stickers I put on the gauges.
http://www.whitegauges.net/products/...ce-Gauges.html
And these are the LED bulbs I used.
http://www.ebay.com/itm/201040481990?ru=http%3A%2F%2Fwww.ebay.com%2Fsch%2Fi.html%3F_from%3DR40%26_sacat%3D0%26_nkw%3D201040481990%26_rdc%3D1
Old Aug 11, 2014 | 10:47 PM
Brians1's Avatar
Brians1
Thanks !
Old Aug 12, 2014 | 10:11 PM
TX-Techman's Avatar
TX-Techman
10 x Ultra Blue T10 8 SMD 3020 LED Wedge Side Light Bulbs Lamps 194 168 2825 921 | eBay
Everyone please check your owners manuals before ordering bulbs because it looks like the later models used T10 base bulbs and earlier models used the 1895 (BA9S) base.
Old Aug 15, 2014 | 10:30 PM
94hokies's Avatar
94hokies
Throwing out more more example, just tested this out tonite while the drivers dash is out of the car. Put in blue and white versions of these to see the difference:
Amico 10 x White BA9S T4W 5 LED SMD 5050 Car Indicator Light Interior Bulb Lamp
White makes the gauges really clear and has a good contrast with the numbers. Blue results in a little dimmer overall lighting affect and gives a nice more modern look. Maybe put the whites in the speedo/tach and the blues in the center console or vice versa, not sure. Only have 10 of each so will have to order more if I wanted to go the same color all the way around.
Console is from a 1969:
Old Aug 16, 2014 | 04:56 PM
'75's Avatar
'75
I put on yellow overlays from white gauges and bright white led's, I get a greenish color with the lights on due to the blue inside the gauge backing.
Old Aug 17, 2014 | 09:05 AM
EasyEd's Avatar
EasyEd
Originally Posted by TX-Techman
Speedo - LED Super White<br/>Tach - Original Bulbs
Speedo and Tach - LED Super White
All Super White LED
One of the best things I have done to my 69 vert, right up there with my Pro-Flow EFI and Mallory SSI Systems
Thanks for all the responses. Great images and ideas. I had thought about red or blue as well as white, but it was real nice to see what they all looked like.
Special thanks to TX-Techman for the comparison photo, above, with LED in tach and incandescent in speedo. That sealed it for me. I'm going old school bulbs. LEDs are a little too stark for me, and even dimmed they might be a distraction at night with my old eyes.
Thanks again,
Ed
