Do I need a cam button?
Old Jul 26, 2002 | 10:17 PM
Jughead's Avatar
Jughead
Senior Member since 1492
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
Default Do I need a cam button?
I've read some posts about using a cam button to prevent the cam from "walking" into the timing cover. In Jegs & Summit the description in the catalog is listed for "roller" cams only. :confused:
Mine is a flat tappet solid. Do I need one?
Len
Old Jul 26, 2002 | 10:21 PM
Pete79L82's Avatar
Pete79L82
Default Re: Do I need a cam button? (1970 Stingray)
You only need a cam buttom on roller cams. The lobes on non-roller cams have a slight taper ground into then that helps to spin the lifter in the bore and force the cam to the rear of the block. Roller lifters can not spin in the bore so roller cams do not have the taper, so they need a button to hold them tight to the block.
Old Jul 27, 2002 | 10:16 AM
GDaina's Avatar
GDaina
Default Re: Do I need a cam button? (Pete79L82)
Old Jul 27, 2002 | 10:55 AM
mountainmotor's Avatar
mountainmotor
Len,,put some assembly lube on the back of the upper timimg gear where it meets the block. When you get the timing cover on then is a good time to flip the motor over and preoil the chain before putting the pan on. Then you can put the lifters in and the heads on ect. Don't forget to put the oil pump drive in before the oil pump! Will save pulling the pan off later.
To Do I need a cam button?
