Toggle Switch Location Ideas
Old Aug 12, 2014 | 12:21 AM
Kim72's Avatar
Kim72
Default Toggle Switch Location Ideas
Looking for ideas on where to mount 2 or 3 toggle switches in a 72 stock interior. Not looking to chew up the interior and I want to have them looking as period correct as I can. Ash tray is already spoken for. Any ideas appreciated.
Old Aug 12, 2014 | 01:33 AM
dembo's Avatar
dembo
Mounted mine on the center console extention driver side, where the original rear window defroster switch is mounted. There's plenty of space behind it. (loosely fit panel and was corrected after the photo). Mine's a mandatory easy to reach rear fog light toggle switch
Nick
Old Aug 12, 2014 | 01:42 AM
ignatz's Avatar
ignatz
drilled a couple of holes in the wiper bezel, like this
Old Aug 12, 2014 | 05:45 AM
oldgto's Avatar
oldgto
I`m also looking for a spot to put 2 toggles.... over-ride switches for my electric headlight & wiper door. Ashtray was my first thought. What`s your ashtray "spoken for"?
Excellent idea! Curious.... what are the LED lights for in the front?
Old Aug 12, 2014 | 11:50 AM
ignatz's Avatar
ignatz
have some relays behind the panel that supply power to an electric fuel pump and an ignition controller. It is handy to be able to shut off either while I'm working on something else, hence the toggles. The LED's show whether power is being supplied. The yellow LED is to an oil pressure switch which shuts off fuel if the motor stalls.
Old Aug 12, 2014 | 01:21 PM
Doug Kraft's Avatar
Doug Kraft
I got an extra wiper benzel, ground off the corvette and mounted the switches in it's place.
Old Aug 12, 2014 | 05:56 PM
oldgto's Avatar
oldgto
I LIKE it! Also interesting is the indicators below the switches... "ignition" and "fuel pump"... where did you find those?
Pics of re-worked bezel?
Kim72, still wondering about your ashtray. I`ve seen an MP3 port of some sort before.
Old Aug 12, 2014 | 06:03 PM
ignatz's Avatar
ignatz
Pegasus Racing has a lot of useful odds'n ends. Found those preprinted there and included in a bigger order
Old Aug 12, 2014 | 06:12 PM
oldgto's Avatar
oldgto
Old Aug 12, 2014 | 08:08 PM
Kim72's Avatar
Kim72
My USB flash drive for my tunes resides in there. Perfect spot. The ashtray door protects it nicely.
I like some of these ideas. There all very interesting. Any others??
Old Aug 12, 2014 | 08:50 PM
Paul L's Avatar
Paul L
Daytime Running Lights (DRLs).
LED-lit toggle when on.
Old Aug 12, 2014 | 08:57 PM
Mooser's Avatar
Mooser
My electric fan override switch is in one of the two superfluous holes on the bracket that holds the trip mileage reset **** just above the left knee. Not something I'm ever hoping to need but if the time comes it's easy to reach.
The other holds the override for my DRL (turns them off completely)
This is the bracket (without the switches)
M
Old Aug 12, 2014 | 09:55 PM
Tim 1973's Avatar
Tim 1973
I put my seat warmer switches on the emg brake console..
To Toggle Switch Location Ideas
