what length Speedo cable on a '78?
This has now bust and I need to order a new one but I've three options on the length:
63 inches
83 inches
100 inches
I dont particularly want/need the cruise control back so I'm happy to stick with the current set-up but which length should I buy?
(I know I could get under the car with a tape measure but I'm being lazy :sleep: )
Further inspection has revealed that the cable has not snapped, but has in fact come away from the tranmission. The 'knurled' connector end of the speedo cable is still in the transmission but the cable has come out and is hanging loose.
Is this repairable or do I have to scrap it and start from scratch with a new cable/connector?
b.t.w. how do I get the 'knurled' connector off the transmission - is it simply a case of unscrewing it? :bb
Paul- cheers for you reply - I'll see if I can fix what I've got first but if not then I'll probably give Ray a ring.
