'77 No Power, Melted Connector
Anyway, we got home no problem, but the next morning, the car was dead. No power at all, not even brake lights. Figuring I drained the battery, I had it charged and tested, and everything came back good. However, still no power to the car at all. No lights, no start.
I'm new to working on cars, so I've spent the last 3 weeks working on this off and on, but I believe I've tracked the issue to a partially melted connector. But first the basics.
I have 12.6v at the battery, at the starter, and at the high speed blower relay. I have 0.0v at the alternator, and 0.0v at the fusebox (should I have any when car off?). I have checked the lone fuseable link I found near the starter, and its good. (There are a number of aftermarket items in the car, so there is a chance the previous owner 'customized' the wiring).
One cable from the starter runs to a connector that sits under the master cylinder, which then goes to: the alternator, the high speed relay, and the hood light. The alternator part of the connector has melted, and the cable no longer makes contact with the metal plate in the connector. Here's a photo annotated with some voltages.
Does anyone have any idea what this connector is called or where to find a replacement? In looking at the factory wiring diagram, the connector is labeled, "2984415" but that is for the non-AC configuration. Mine has AC, so I think its part number "8900635", but the 'with AC' diagram is not as detailed, so I'm not sure.
If anyone can help me on the part, I would appreciate it. Also, there's a chance I'm way off on this, so if anyone has other suggestions for a '77 with no power, I'm happy to hear them. I have found a lot of threads on this already, but none have helped my issue.
Thanks!
http://www.lectriclimited.com/mainpage.htm
http://www.repairconnector.com/categ...OR-CONNECTORS/
Glad this thread helped you out,
Neal
I clipped out the entire connector, put the blower motor relay cables in one end of a crimping tube, then the cable from the starter and the one to the alternator in the other end. The lightbulb socket on the hood was physically damaged and wouldn't hold a bulb, so I just clipped that cable out of the car. Used a mini torch to apply some insulation, and its never been a problem since.
When you removed your old Tap Connector, did you find it to have the hood light cavity extension built into the main body of the 8900635? Almost looks as if both connectors were used as one to tie-in on A/C cars?
The other number you posted 2984415 has the extension but out of stock.
Good to see you solved your issue.
2984415 Link: https://www.connectorpeople.com/Connector/DELPHI-PACKARD/2/2984415
8900635 Link: https://www.connectorpeople.com/Conn...ARD/0/08900635
Early 77 Hood Light Assembly: https://www.ebay.com/itm/1977E-Corve...EAAOSwhktau6~~
