hookup for s/b vacuum modulator valve
Old Jul 27, 2002 | 07:33 AM
stumpbuster's Avatar
stumpbuster
Default hookup for s/b vacuum modulator valve
o.k. guys, help is needed again. where does the vacuum modulator valve get its vacuum from. is it connected to the carb or the manifold. does it make a differance? does this line need to be medal or can rubber be used! thanks again...........
Old Jul 27, 2002 | 09:09 AM
Chuck Gongloff's Avatar
Chuck Gongloff
Active Streak: 90 Days
Default Re: hookup for s/b vacuum modulator valve (stumpbuster)
On my 69 BB, the fitting is in the back of the intake, behind the last carb. I have a rubber hose that runs to the trans. There are many configurations for the fittings, depending on options, PB and automatic are two that come to mind. Chuck
