Dashboard wires help
Old Aug 14, 2014 | 12:37 PM
FromRGV's Avatar
FromRGV
7th Gear
Default Dashboard wires help
Im reassembling my dash and im on the process of reinstalling the speedo and tach, most wires are labeled but there are these washer like wires i am not sure were they belong one of them is grey the other is black.
The wires come off the tachometer side of the wire harness I have a feeling they belong screwed to the hex screws on the back of the tach and should work as ground.
Old Aug 14, 2014 | 12:45 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
What model year?
Old Aug 14, 2014 | 12:48 PM
FromRGV's Avatar
FromRGV
7th Gear
1977, any idea where they belong?
Old Aug 14, 2014 | 01:05 PM
doorgunner's Avatar
doorgunner
2026 Loser of the Year
We need another "Stickey" for new members like me......
"10 Rules to follow when repairing your car"
One of the rules should be "Take photos of each component before disconnecting/removing it or anything attached to it"
(Photos have great memories of where things belong)
Old Aug 14, 2014 | 01:09 PM
FromRGV's Avatar
FromRGV
7th Gear
definitely or at least mark the wires, learned my lesson.
Old Aug 14, 2014 | 01:43 PM
FromRGV's Avatar
FromRGV
7th Gear
I found a diagram for my car and I think I located the wires I am talking about. They Should be for the HTR & AC ILLUM LP... whatever that is. I'm considering going without them.
Old Aug 14, 2014 | 02:28 PM
Peterbuilt's Avatar
Peterbuilt
Looks like those wires should have a bulb socket on the end and it plugs into the back of the heat / AC control.
With the parking or headlights on the gray wire brings 12 volts to the socket and the black is the ground.
Old Aug 18, 2014 | 10:33 PM
Bob E's Avatar
Bob E
On my '78----That plugs into two wires of the same colour and goes to a bulb in the top center of your dash panel,(above the air louvers from the heater) The light shines down on the A/C heater controls. Please correct me if I am Wrong----boB
To Dashboard wires help
