Inline fuel regulator recommendations
Old Aug 14, 2014 | 10:28 PM
rajin cajin's Avatar
rajin cajin
Default Inline fuel regulator recommendations
I just replaced the original carb on a l82 350 with a holley 600. I have started the car a few previous times for 5 - 10 seconds due to no water pump belt on. Finally got the belt on, started and let idle. It ran for a minute or so and then idled down and stalled. I then noticed fuel dripping from the secondary boosters and throttle shafts (this is a new carb). I have an inline filter but found all kinds of trash in the bowls when I pulled them (floats were free). There is nothing coming out of the bowl vents. It has never backfired so I assume the power valve is fine. I have not tried to start since putting the bowls back on, and I assume the fuel pump may have to much pressure (new fuel pump and tank). I have read that 5.5 lbs is what the holley carbs like and that the factory mechanical fuel pump is pushing 8-9 lbs. So it looks like an inline regulator is in order. Is it a waste of time to put a $30 autozone regulator on versus a high dollar one?? Motor is stock except for aftermarket intake, carb, HEI distributor and hooker side pipes.
Old Aug 14, 2014 | 11:01 PM
Mike Ward's Avatar
Mike Ward
Nope. 4-5 is normal.
