Pulling engine...?
Old Aug 15, 2014 | 12:05 PM
Factor's Avatar
Factor
Default Pulling engine...?
Hi all,
trying to pull the engine in my 69 convert...took off the hood...rolled the engine hoist/picker up to the front...and it DOESNT work?
it hits the nose...which obviously is not good...
how did you guys do it with the nose on?
overhead hoist?...
thanks,
R
Old Aug 15, 2014 | 12:12 PM
stu_h's Avatar
stu_h
2nd Gear
I removed the hood and pulled the engine from the drivers side. Some people will say you need to remove the wheel, but I did not. Not a difficult job.
stu
Old Aug 15, 2014 | 12:13 PM
tyancey00's Avatar
tyancey00
stu
same here... Works fine from the side.
Old Aug 15, 2014 | 12:42 PM
MrJlr's Avatar
MrJlr
From the side...I did jack stand one side and remove the wheel....just easier to me...
Old Aug 15, 2014 | 01:02 PM
Shark Racer's Avatar
Shark Racer
I did mine from the driver's side, did not remove the hood or radiator. Transmission (TKO) was removed seperately.
Old Aug 15, 2014 | 02:01 PM
Madhatr's Avatar
Madhatr
I told my wife I needed to buy one with a shorter front end!
that didn't go over well.... So like the others stated, from the side
Old Aug 15, 2014 | 02:11 PM
resdoggie's Avatar
resdoggie
Had a 1976 L-82, 4-sp
Royal Canadian Navy
Ditto. From the passenger side. More room i.e. pb amd m/c is not in the way. Either side works. Personal preference.
Old Aug 15, 2014 | 02:12 PM
resdoggie's Avatar
resdoggie
Royal Canadian Navy
My wife helped me pull the engine!
Old Aug 15, 2014 | 02:25 PM
CaseyJones's Avatar
CaseyJones
St. Jude Donor '15-'16
She's a keeper for sure!
Old Aug 15, 2014 | 02:27 PM
resdoggie's Avatar
resdoggie
Royal Canadian Navy
High maintenance though.
Old Aug 15, 2014 | 08:15 PM
Factor's Avatar
Factor
OMG! love the comments!
and yes! thanks for hte info! Will do tomorrow morn!!!
Thanks!
R
Old Aug 16, 2014 | 02:58 PM
Factor's Avatar
Factor
All good! Pulled from drivers side! put the hoist base around the front tire.
worked great! thanks for the help!
R
Old Aug 16, 2014 | 03:45 PM
Chinaski's Avatar
Chinaski
St. Jude Donor '14
Pulled mine (Engine and Trans) from the passenger side, will be reinstalling from the passenger side as well here in a day or so.
If you have a hoist with a long enough arm on it, I suppose you could do it from the front...
Out with the old...
Old Aug 16, 2014 | 06:39 PM
Cavu2u's Avatar
Cavu2u
Chinaski,
Do you consider it easier to pull the tranny along with the block, instead of just pulling out the engine?
I'm about to rebuild the car's original block, and temporarily replace it with this:
Just wondering why you pulled the transmission too. I'm as lazy as they come.
Thanks.
Steve
Old Aug 16, 2014 | 10:07 PM
Chinaski's Avatar
Chinaski
St. Jude Donor '14
Originally Posted by Cavu2u
Chinaski,
Thanks.
Steve
It's easier to pull both as a unit, ESPECIALLY if it is a manual car. I was planning on having my transmission rebuilt anyway, so it was a no brainer.
Few pics from today...Motor going in Monday.
Old Aug 16, 2014 | 10:31 PM
Cavu2u's Avatar
Cavu2u
Ah..KC Chiefs Red I see. Is it a '73?
I have an automatic. I'll just pull the motor, for the transmission is good. A few U-joints could be changed, but other than that, drivetrain is satisfactory.
Steve
Old Aug 17, 2014 | 10:25 AM
Chinaski's Avatar
Chinaski
St. Jude Donor '14
Steve
Yes, a '73.
If you have an auto, no need to pull the trans unless you are planning on servicing it.
GO CHIEFS!
To Pulling engine...?
Old Aug 17, 2014 | 11:42 AM
BlackC3vette's Avatar
BlackC3vette
R
I put my small block back in with the 4 speed bolted on. I raised the rear and used a leveler. It went right in, no problems.
Old Aug 17, 2014 | 11:50 AM
C3Hawk's Avatar
C3Hawk
Any idea of the clearance height (between fender and ceiling) you needed to do this?
Thanks.
Old Aug 17, 2014 | 01:18 PM
Cavu2u's Avatar
Cavu2u
Thanks.
Well, if I understand you correctly, that depends on how long your chain setup is between top of hoist to block, plus the overall height of the engine. That must be a consideration if working inside a garage I guess.
