Headers
Old Aug 16, 2014 | 02:47 AM
eurekax's Avatar
eurekax
Default Headers
Looking to fit Headers to my 72 Vette with stock 200 hp motor and stock exhaust,can someone advise what model headers will suit this motor Thanks Alan
Old Aug 16, 2014 | 03:23 AM
c3_dk's Avatar
c3_dk
https://www.holley.com/products/exha...parts/31106FLT
or
https://www.holley.com/products/exha...parts/11106FLT
Old Aug 16, 2014 | 04:21 AM
terrys6t8roadster's Avatar
terrys6t8roadster
Ceramic coated should be high on the list of options. They keep the under hood temps down. Also some companies have a ball socket on the collector end [Hooker I think]. I really like that option, no gasket required or ever to blow out. Plus easier alignment. As c3 dk showed, long tube headers are best for power increase. 1 5/8 tube dia is good up to at least 500 flywheel HP. T
Old Aug 16, 2014 | 08:00 PM
blue427's Avatar
blue427
I could be wrong but I think the stock manifolds for a 200h.p. engine are adaquate,with headers you'll lose some low rpm torque and gain at the higher rpm range. Since a 200h.p. 350 c.i. has a low rpm limit,you'll never gain what you've lost.Aside from a good tune up low restrictive mufflers might be better.Another thing to consider is go 1 or 2 gears steeper in the rear,if you have a 3 series carrier it would'nt be that expensive. If you're going to do mods to the engine forget this advice.
Old Aug 16, 2014 | 08:12 PM
7t9l82's Avatar
7t9l82
oh yes, tremendous power drop at low speed from about 800 R.P.M to about 1500. after that its all over. this power loss nonsense is way overplayed.
Old Aug 18, 2014 | 05:15 PM
eurekax's Avatar
eurekax
Thanks for all your replies,some good tips !! Thanks Alan
To Headers
