Need Clutch Experts
I't makes a spinning sound when I press in the clutch and it goes away when I let it out. I had the same problem with the last Dual Friction I took out. There was no rub marks any where on the weights or the pressure plate or the clutch fork that holds the throw out bearing. I't sounds like the throw out bearing but the one I took out before looked fine. I'm alittle puzzled :confused: Any suggestions?
