75 HEI Dist specs
Old Aug 22, 2014 | 10:20 PM
Mod75's Avatar
Mod75
2024 C3 of the Year Winner - Modified
Default 75 HEI Dist specs
Cleaning up my vette paper work folders and came across this, had the HEI re-curved way back in 1976. This is for my 75 L48, turbo400, 308.
Stock degrees at rpm
Begin at 2 1350 rpm
6.5 at 2000 rpm
10 at 3400 rpm
Full at 11 4200 rpm
Modified degrees at rpm
2 at 850 rpm
6 at 1050 rpm
10 at 1850 rpm
Full at 11 at 2200 rpm
Anybody else with dist re-curved and what are your specs for a mild L48 top-end mod?
Old Aug 25, 2014 | 11:38 AM
MelWff's Avatar
MelWff
Those degree readings would have to be distributor degrees which would double for crankshaft. So 22 degrees at 2200 rpm with 14 degrees initial would give you the 36 total needed.
