Rotor Phasing
Old Aug 23, 2014 | 04:29 PM
akdale's Avatar
akdale
Default Rotor Phasing
I installed a MSD 6530. Locked dizzy out and it's up and running. Great little ignitoin box. I am looking at the rotor phasing and at idle it is to one side of the terminal firing almost in the middle of the two terminals, but closest to the one I am monitoring. Increase rpm for full advance and it lines right up to the terminal I have the timing light connected to. I figure since it is at higher rpm that this is likely most important I should be fine. Any opinions on my logic?
I have an HEI so its going to be a bit of a pain changing the phase
Old Aug 25, 2014 | 11:57 AM
MelWff's Avatar
MelWff
based on this document your logic appears correct.
http://www.msdignition.com/uploadedF...or_phasing.pdf
Old Aug 25, 2014 | 12:58 PM
akdale's Avatar
akdale
I found an msd video too that shows optimal phasing. Once I get the curve dialed in I might mess around with it.
To Rotor Phasing
