1972 dash harness wire ID
Old Aug 23, 2014 | 10:25 PM
rajin cajin's Avatar
rajin cajin
Default 1972 dash harness wire ID
I have been cleaning up the dash harness and have a couple of cut wires. I have lectric and NCRS but can't seem to locate these wires. The 1st is a black and white by the fuse box. I know black is usually ground, but this does not appear 14 ga.
Second is a solitary white that has a male/female connector and then the wire goes over the steering column and then was cut. It also is in the part of the harness running in the drives door jamb (through the opening of the body mount point) to the rear of the car.
Any info is appreciated.
Old Aug 24, 2014 | 12:39 AM
VCuomo's Avatar
VCuomo
The single white wire is probably for the rear courtesy lamp.
Old Aug 24, 2014 | 03:10 PM
rajin cajin
Thanks V.
Old Aug 24, 2014 | 10:27 PM
Yeznat's Avatar
Yeznat
in the pic with the fuse box
on my 72 I have the factory alarm and the black and white wires go to the alarm system in the door jamb drivers side
Old Aug 24, 2014 | 10:40 PM
Yeznat's Avatar
Yeznat
Does your car have the alarm system with the key in the rear , I am new to the corvette world and it took me a while to figure out what the key in the back was for (No remotes or key fobs in 72)
Old Aug 25, 2014 | 08:10 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by Yeznat
...Does your car have the alarm system with the key in the rear...
All 72s had factory alarm. The owner's manual explains how to arm and disarm it.
Old Aug 25, 2014 | 02:06 PM
rajin cajin
Will check when I get home. Thanks.
Old Aug 25, 2014 | 02:16 PM
Ranger24's Avatar
Ranger24
I also recommend Dr. Rebuild's laminated wire diagrams; I find them extremely helpful with running down mystery (bubbadized) wiring like you described.
To 1972 dash harness wire ID
