fan clutch question
Old Aug 24, 2014 | 08:24 AM
sgt kohler's Avatar
sgt kohler
Default fan clutch question
whats the difference between a fan clutch for a car with ac and one without? also the 7 blade fan as opposed to a 6 blade fan?
Old Aug 24, 2014 | 01:59 PM
REELAV8R's Avatar
REELAV8R
Non A/C cars usually have the standard duty clutch fan and A/C equipped cars have the heavy duty clutch fan.
The number of blades and the pitch, diameter and cord (distance from leading edge to the trailing edge of the blade) control how much air the blade is capable of moving.
http://www.haydenauto.com/featured%2...s/content.aspx
Old Aug 24, 2014 | 04:41 PM
jb78L-82's Avatar
jb78L-82
I can tell you in 78 the Corvette cars without A/C got a standard thermostatically controlled fan clutch that engaged at 180 degrees. The base cars (L-48) with A/C got a heavy duty thermostatic fan clutch that engaged at 185 degrees and the L-82 cars with A/C got a thermostatic fan clutch that engaged at 190 degrees.All info from the 1978 GM service manual.
To fan clutch question
