c3 solid axle pics
Old Aug 27, 2014 | 10:36 PM
d555's Avatar
d555
Originally Posted by jc76
I got aluminum dart small block 3.625 stroke crank 4.155 bore with all pro 13 degree heads has 14.5-1 but i am going to go down to 11-1 have it all tore down so I don't know the hp when done probably enough. I am thinking about a tremec magnum 6spd for the trans haven't took the plunge yet
Looks like a fun project. Nice starter motor you have there!
393" ex Dirt motor?
Old Aug 27, 2014 | 10:44 PM
jc76's Avatar
jc76
393" ex Dirt motor?
yes, thats a good guess you must like going in circles
Old Aug 28, 2014 | 01:45 PM
Rkreigh's Avatar
Rkreigh
beautiful work!! rear looks like it will take most anything you can put down
let us know how the 60 ft is!
very nice fabrication!
Old Oct 12, 2014 | 05:19 PM
jc76's Avatar
jc76
here are some pics of the cross member in front of the axle after I made it lower for some drive shaft clearance
Old Oct 13, 2014 | 10:33 AM
tektrans's Avatar
tektrans
Nice fab work-it looks factory.
Old Oct 19, 2014 | 08:15 AM
Jamess411's Avatar
Jamess411
This is what 30 inches of tire looks like from the rear.
Old Oct 19, 2014 | 01:03 PM
sagebrush rebel's Avatar
sagebrush rebel
Default Tires
What brand and size tires do you have? I have a 68 Canam I would like to put something similar on it. Thanks Don
Old Oct 19, 2014 | 02:45 PM
Jamess411's Avatar
Jamess411
they are 29x15x15 MT S/R
might have been able to fit 30s but went safe.
Old Oct 19, 2014 | 08:04 PM
tektrans's Avatar
tektrans
Bad ***!
Old Oct 19, 2014 | 09:36 PM
jc76's Avatar
jc76
This is what 30 inches of tire looks like from the rear.[/QUOTE]
real nice thanks for pic
Old Oct 19, 2014 | 09:45 PM
jc76's Avatar
jc76
frame and rear diff pics
Old Oct 19, 2014 | 10:09 PM
jkippin's Avatar
jkippin
why is one of your tires mounted backwards??
Old Oct 21, 2014 | 12:25 AM
  #33
Jamess411's Avatar
Jamess411
Because Summit messed it up lol…I have to get one flipped around.
I ordered them already mounted on the new rims.
Old Nov 23, 2014 | 12:42 PM
  #34
jc76's Avatar
jc76
pics
Old Nov 23, 2014 | 10:50 PM
  #35
tektrans's Avatar
tektrans
Looks GREAT!!
Old Nov 24, 2014 | 02:06 AM
  #36
ajrothm's Avatar
ajrothm
Looks awesome! Nice work!!
Old Nov 26, 2014 | 06:42 AM
  #37
tektrans's Avatar
tektrans
2 questions
1-Which front coil overs did you go with?
2-If the coil overs are bolted in from underneath how do you feel about all that weight of the car supported by basically 4 bolts?
To c3 solid axle pics
Old Dec 8, 2014 | 10:02 PM
  #38
jc76's Avatar
jc76
Originally Posted by tektrans
2 questions
Qa 1 for 67-9 camaro they set on top of the a arms and I welded d shaped sheet metal tabs on top of the arms then re drilled the mount holes through them so it is a 1/4'' thick where the weight is on the arms sorry for slow reply haven't been on here
Old Jan 3, 2015 | 02:02 PM
  #39
jc76's Avatar
jc76
pics with body on
Old Jan 3, 2015 | 10:32 PM
  #40
JoeC427's Avatar
JoeC427
pics with body on
Awesome build man!
Looking forward to the finished product.
