Check Engine Light + No codes
Old Aug 25, 2014 | 08:03 PM
LuVettes's Avatar
LuVettes
Default Check Engine Light + No codes
Hi Guys,
Long time no see. I have the 81 in the shop right now. They have gone through it and she drives ok and seems to run fine. The check engine light is still on though.
I spoke to the tech and they said that it is not communicating and thus not throwing codes.
Is there anything I should try? Ignore it since it is running, or replace the ECM? Has anyone had a similar issue with some suggestions?
Old Aug 26, 2014 | 10:13 AM
MelWff's Avatar
MelWff
On OBDII systems that is a sign of a blown fuse, typically the cigarette lighter, not sure if it is the same as OBDI. Is this shop experienced with GM OBDI systems? Is the tech ASE qualified?
Old Aug 26, 2014 | 05:05 PM
LuVettes's Avatar
LuVettes
They are ASE Certified techs. While they are not a vette specialty shop, they have worked on my 81 & 85 periodically over the past 20 years.
Old Aug 26, 2014 | 11:38 PM
maxmachz's Avatar
maxmachz
Simply unplugging any sensor or the distributor plug will throw the light. Anyone can read the ecm with a jumper wire on these, the CEL will flash the information with a number of blinks and pauses. The plug for checking it is under the ashtray. Plenty of info on here to do it all yourself.
Old Aug 27, 2014 | 12:37 PM
hugie82's Avatar
hugie82
Any harbor freight has a cheap scan tool. It seems many shops now a days don't have the old ALDL scan tools anymore. They plug their new stuff in and they get nothing. The scan tool is cheap or jump it. It's outlined in the manual but it's sometimes hard to keep track of the number of blinks
Old Aug 27, 2014 | 02:39 PM
Brians1's Avatar
Brians1
I am an 81 owner with a fully functional CCC and I have gone to great lengths to understand the system and keep it operational.
The system is an OBD I (5 or 12 pin ALDL interface = most are 5 pin in the ashtray) - get on ebay and look for an "OTC Monitor 85" it's the original scan tool and is excellent. Search this forum for that verbiage ("OTC Monitor 85") and you will see my post with a video, etc on its use and value. The light can be on with a code but a OBD II is not going to catch it.
until you get that - as previously mentioned jump the pin's and read the blinks. On that same post i have a link for you to conact me to get the full manual of the scan tool that includes the who/what/why of the codes (have to e-mail it - its a huge file)
best of luck
Brian
To Check Engine Light + No codes
