Replacing front end bushings, replace springs ?
Old Sep 2, 2014 | 10:07 PM
Brians1's Avatar
Brians1
Default Replacing front end bushings, replace springs ?
I'm doing a poly bushing kit on front end...81 with auto TH350...87k miles
My ride height looks and feels fine...so as the title states....do I put new springs in or not.."this is a "while I'm at it" moment lol
Old Sep 2, 2014 | 10:10 PM
7t9l82's Avatar
7t9l82
springs will sag over time, one of mine was broken and had been for years and never knew it.
Old Sep 2, 2014 | 10:17 PM
Brians1's Avatar
Brians1
Yea...its 75 bucks for a new pair...might as well for peace of mind
Old Sep 3, 2014 | 06:18 AM
bashcraft's Avatar
bashcraft
Why would you change them if there's nothing wrong with them?
Old Sep 3, 2014 | 06:32 AM
JimT's Avatar
JimT
Now is the perfect time!!!!!!!
Also a good time to do a little undercarriage repairs/cleanup/painting. Find an industrial powdercoating company and have your a-arms coated. Some will coat small parts along with large orders and the cost is minimal.
Good luck.
Old Sep 3, 2014 | 07:55 AM
76Rat's Avatar
76Rat
Replacing the bushings is a good thing. Why replace the springs if everything is riding and handling fine.
The springs can be replaced at any time. A little bit of a pain in the butt, but not a big job.
Why fix it if it's not broke.
Old Sep 3, 2014 | 09:58 AM
SteveTheCorvette's Avatar
SteveTheCorvette
If they haven't been replaced at all, they might be worn out, but if your ride height is OK, the existing ones are probably fine. On the other hand the springs need to be pulled either way, and the replace is a fairly inexpensive one. If you are asking the question it usually means you should just do it. I always take advantage of cheap peace of mind.
Old Sep 3, 2014 | 10:09 AM
Brians1's Avatar
Brians1
Yep....its why I asked..for 75 bucks..the whole front end is "new" for the suspension.
Old Sep 3, 2014 | 03:18 PM
Haggisbash's Avatar
Haggisbash
Hi Brians1, if the car in question is the one in your avatar it looks to be riding a little lower than standard, so assuming it has original springs and they have not been cut I would say there is a good chance they have sagged a little. I had the same issue with my 70 and when I pulled the springs I found that even though they were a lot longer than the heavier 430lb springs I fitted they rode a good inch or more lower. The original springs are progressively wound at the top and I could see where the coils had rubbed together so I figured they were getting sacked out. You might find that if you change the springs you wont like the cars new stance but it will ride better. While you are at it what are the shocks like?
Old Sep 3, 2014 | 03:33 PM
gjohnson's Avatar
gjohnson
I'd do it. The stock springs were a little "soft" when they were new IMO.
Old Sep 3, 2014 | 08:46 PM
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
If you have cause, then yes, now would be the best time.
That said, if they're not sagging adversely and your intentions don't include increasing the spring rate and/or changing ride heights, then IMCO there isn't much cause.
Old Sep 4, 2014 | 10:52 AM
76Rat's Avatar
76Rat
This.
Old Sep 4, 2014 | 11:08 AM
billcarson's Avatar
billcarson
i did the front bushing job,used rubber,and resisted the,"while you are in there bug",and i have done that for my entire project.i do not regret this as $ was well spent on worn out parts instead.i just painted mine black and put them back.
Old Sep 4, 2014 | 01:04 PM
Brians1's Avatar
Brians1
Thanks for all the great feed back gents...this form is the best
I went ahead and ordered the springs...if I don't like for whatever reason..I'll put old back on
I will take measurements of before and after ride height ..I'm still running the stock 15's my 81 came with
To Replacing front end bushings, replace springs ?
