Steering issues/gear box
Old Sep 4, 2014 | 11:23 AM
czardali's Avatar
czardali
Default Steering issues/gear box
I recently got my inner tie rods replaced,new swaybar/links. I went to get an alignment and was shown the play in my wheels from the power steering valve and was told to replace the gear box. I was looking up parts for the gear box and there are multiple types! How do I know which one to buy? Do I need to find the casting number? If so where is it located? Thanks in advance fellas!
Old Sep 4, 2014 | 11:31 AM
MelWff's Avatar
MelWff
the power steering valve is not part of the steering box. Did they show you the play in the steering valve with the engine running, if not they are trying to sell you something. The steering box itself has an adjustment screw and locknut which would be the first thing to try before going for a new box.
Old Sep 4, 2014 | 11:57 AM
Paul L's Avatar
Paul L
The stock box is pretty much the same over the years. I am not sure what you mean by "multiple types". I don't know if it has a casting number. As Mel said, you can try adjusting it but you have to be careful not to over-tighten.
Old Sep 4, 2014 | 01:16 PM
Ontario73's Avatar
Ontario73
As Paul and Mel have suggested, try adjusting the lash in the box first. The simple 2 tool adjustment (instructions can be found with a quick search) only takes a minute and can save you money. Mel is also correct that the PS control valve can't be checked without the engine running and fluid in the system; the valve has no resistance without fluid pressure.
In the shop's defense, I doubt many of the younger guys have ever seen our set-ups before!
Old Sep 4, 2014 | 01:19 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by Ontario73
...In the shop's defense, I doubt many of the younger guys have ever seen our set-ups before...
That's a possibility, but even at that, they should not be recommending replacing parts which may not need replacement.
Let's face it: they were guessing.
Old Sep 4, 2014 | 03:58 PM
czardali's Avatar
czardali
no, they did not show me the play in the wheel with the car running. The car has a hard pull to the left and its annoying the crap outta me. How would I explain to a mechanic to check my steering box?
Old Sep 4, 2014 | 04:02 PM
czardali's Avatar
czardali
What I meant by multiple types was me doing a Google search on gear boxes. You fellas tellin me that adjusting my steering box is gonna straighten my hard pull? Im down. I'll do a search and a Go Pro vid update.
Old Sep 4, 2014 | 04:28 PM
MelWff's Avatar
MelWff
the hard pull to the left is when you are just driving in the center lane of a multi lane highway or when you step on the brakes?
Nobody here is telling you the hard pull has anything to do with the steering box because it doesnt. A incorrectly adjusted steering valve can cause a hard pull as well as the alignment requiring adjustment. If you have to explain to the mechanic you need a different shop that is familar with this generation of car. Contact a local Corvette club and find out who the members go to for work on their cars.
Read the last page of this link concerning sector shaft adjustment.
http://jimshea.corvettefaq.com/?p=810
Old Sep 4, 2014 | 06:38 PM
Paul L's Avatar
Paul L
I am going to back off at this point. The pic I showed was a blueprinted box done by Gary R. It has worked perfectly for three years now.
As to how adjust your box, Jim Shea has detailed instructions. I hope he chimes in.
Old Sep 4, 2014 | 07:28 PM
jb78L-82's Avatar
jb78L-82
I have the same by Gary-4 years now. His boxes are better than an OEM box due to his customization and blue printing of the box.
Old Sep 4, 2014 | 08:00 PM
Paul L's Avatar
Paul L
True. But we can't say that here .
Old Sep 5, 2014 | 06:14 AM
jb78L-82's Avatar
jb78L-82
Oops!……..
Old Sep 5, 2014 | 08:53 AM
Jim Shea's Avatar
Jim Shea
Oops!……..
Have you tried swapping front tires? If the pull reverses itself, you have bad tire(s).
There is an adjuster screw and lock nut on the top cover of the gear. Are there threads extending above the lock nut? If no threads are showing, your gear does not have any adjustment left. Then it should go to Gary.
Let's go on from here.
Jim
Old Sep 5, 2014 | 10:43 AM
czardali's Avatar
czardali
this weekend. im gonna post a video and then im gonna do the steering adjustment as suggested.
Old Sep 5, 2014 | 12:04 PM
Mike Ward's Avatar
Mike Ward
Then you can safely ignore anything these idiots might have said. All C3s with power steering have a large amount of free play in the steering wheel with the engine shut off.
The pull to the left has nothing to do with free play or a worn steering gearbox. Try balancing the control valve as a first step. It's an easy 5 minute job.
Old Sep 5, 2014 | 12:44 PM
Kevova's Avatar
Kevova
Power assist as it correctly called, IMO it was so bad it was designed to be easily removed from car forever. Control valve causes most if not all steering issues. Find shop that specializes in c2-c3 corvettes since they share so much.
Old Sep 5, 2014 | 01:38 PM
Mike Ward's Avatar
Mike Ward
Originally Posted by Kevova
Power assist as it correctly called, IMO it was so designed to be easily added to the car as it was originally an option. Control valve causes some steering issues. Find shop that specializes in c2-c3 corvettes since they share so much and so many garages don't have a clue.
FTFY
I have all the original components on my 41 year old car, except the hoses. That's about 25 more years than the design life.
Old Sep 6, 2014 | 05:23 PM
czardali's Avatar
czardali
I'm doing some reaserch first. Starting with this guy.
Old Sep 6, 2014 | 05:37 PM
czardali's Avatar
czardali
im also gonna do that jim shea, just collecting the tools first
To Steering issues/gear box
