What do you guys think about HEI replacement distributors? Which ones do you like, suggest? I'm looking to replace my stock distributor with something new, as I don't feel like rebuilding/messing with mine, and I think now is a good time to address the issue.
Also, when replacing, is it pretty much a simple swap out-swap in deal? Or is there something else I should be looking for? Lastly, on my old manifold, there is this little metal cylinder that has a wire going from it to the distributor. What is this? Does it need to be part of the swap? Will it be replaced by the new distributor?
call these guys in memphis , tn . I 've had them build a couple of distrib for me if you ever change your setup they resetup your distrib. nice product http://www.performancedistributors.com
