T-56 console - shift plate cover
Old Sep 11, 2014 | 03:44 PM
Hofs01's Avatar
Hofs01
Default T-56 console - shift plate cover
Hey guys, I wanted to show off my shift plate that I built for my 78.
The center sections of the old plate (inside the silver trim) was gutted with a razor knife. I then built this plate to fit into the silver trim area. I left just enough area to bolt the plate onto. I then had a local sign company wrap it to closely match the rest of the interior (not as close as I would like). I am overall pretty happy with how it turned out. What do you think?
Old Sep 11, 2014 | 04:41 PM
SH-60B's Avatar
SH-60B
That looks very good. I put the switches all the way down to the rear of the shifter and used a Lokar round mount ring and boot, and kept the lighter as a power tap. I used a combination primer and color paint from Duplicolor IIRC, matches as well as yours does. Good job there, very clean looking, be proud of it. What shifter did you use? I used the MGW.
Old Sep 11, 2014 | 05:12 PM
Hofs01's Avatar
Hofs01
Thanks,
You should post up a pic of yours please, I would like to see it. I wanted a power tap but also wanted a clean look. The lighter will go in between the two seats in the vertical section of the floor pan. I went with the PRO 5.0 shifter as it had the very good reviews and the trans came with it.
as for the switches, I wanted them below the shifter but there was just no room with that big shifter bracket.
Old Sep 11, 2014 | 07:36 PM
MIKE80's Avatar
MIKE80
Nice job! Looks great.
I kept mine stock looking.
Old Sep 11, 2014 | 09:21 PM
Hofs01's Avatar
Hofs01
Mike, I really wanted it to look stock like yours. However, that 5.0 shifter with the stop ring hampered my chances of that. I really like how yours looks
Old Sep 11, 2014 | 11:00 PM
72LS1Vette's Avatar
72LS1Vette
I went for the stock look also. I fabbed an offset shifter mount and my son cut the plate and made the pattern decal at his shop. The short shifter is a Hurst part that is intended for a Mustang IIRC.
Rick B.
Old Sep 12, 2014 | 03:10 PM
MIKE80's Avatar
MIKE80
Thanks!
I do have 1 question.. did you move your heat/ ac controls? Don't see it.
Old Sep 17, 2014 | 12:18 PM
Hofs01's Avatar
Hofs01
Thanks!
I removed the AC and do not have the heater hoses hooked up. I just wire tied them below the new console. I didnt want them to be up there and useless. I have it set on defrost and will wire in a hidden fan switch in case I need the defrost at night. This car is really just a weekend car.
Old Sep 18, 2014 | 11:26 AM
worship79's Avatar
worship79
Looks slick!
Old Sep 19, 2014 | 12:31 AM
cagotzmann's Avatar
cagotzmann
Nice but I would like to hear how the T56 fit in the 78 corvette. Did you find a kit to install or buy parts and make it fit.
To T-56 console - shift plate cover
